Replaced lcd, now hard keys dont work... help??
This is a discussion on Replaced lcd, now hard keys dont work... help?? within the Droid X Help forums, part of the Droid X Discussion category; so i decided that rather than pay the $99 insurance fee for a phone that arguably isnt work a hundred bucks, i would replace my ...
Thread: Replaced lcd, now hard keys dont work... help??
    Question Replaced lcd, now hard keys dont work... help??
    so i decided that rather than pay the $99 insurance fee for a phone that arguably isnt work a hundred bucks, i would replace my lcd screen since i had dropped it and there was some bleeding involved. I got the screen in, took everything apart, installed new screen, reassembled, and booted up to find that my 4 bottom hard keys didnt work. the power button and camera button works fine, but the volume and bottom keys arent working correctly. also, it wants to go to speech input randomly. I am assuming that I just dont have one of the ribbon cables on right via one of the many contact points. but i have traced them back as far as i can, cleaned with rubbing alcohol, everything i can think of with no avail. any help that you guys/girls could give me would be appreciated. I really cant afford to replace this phone right now. thanks! -david
    note: i have tried to do a hard reset, but since the home key doesnt work, it will not let me. also, i just assumed that since it worked fine before, and this was the only thing that i have done since it worked, that it was a hardware/user error issue rather than software.
    Points: 907, Level: 16
    Level completed: 7%, Points required for next Level: 93
    MDXer's Avatar
    44502
    Jul 2011
    I just did this today and I am having the exact same problem, but my volume keys and menu key works. Also, I got sent a bad replacement LCD. Go figure.
    Points: 1,682, Level: 23
    Level completed: 82%, Points required for next Level: 18
    Overall activity: 2.2%
    rewwky1846's Avatar
    33086
    32
    Did either of you figgure out the problem? I too had my digitizer and lcd replaced at the same time on two of my DXs, now the home key and mic doesn't work on either phone. That's more than coincidental.
  1. Hard Buttons WON"T light after Insurance Replaced Phone
    By VAlcenius in forum Droid X FAQs
    Last Post: 11-30-2011, 05:15 PM
  2. Hard keys no longer work
    By dj923 in forum Gingerbread Help
    Last Post: 07-27-2011, 01:22 PM
  3. Replies: 4
    Last Post: 05-29-2011, 12:10 PM
  4. Hard keys on off?
    By Chessnut in forum Gingerbread Development and Hacking
    Last Post: 04-29-2011, 05:39 PM
  5. Hard Home and Search keys do not work
    By R1Droid in forum Droid X Help
    Last Post: 09-25-2010, 03:39 PM
droid x buttons dont work
droid x lcd replacement
droid x lcd replacement kit
droid x will not power on after lcd replacement
lcd replace menu not working
replaced screen and keys dont
replaced screen on thuinderbolt nnow meno buttons wont wokr
replaced the digitizer in the droid x now the buttons won't work
reset hardware buttons after lcd replacement
thunderbolt keys dont work
