Tried to Go to CM9, Now Stuck!
This is a discussion on Tried to Go to CM9, Now Stuck! within the Droid X Help forums, part of the Droid X Discussion category; Ok, so I did it.... and everything seemed to have gone through quickly. When I reboot it comes to the beautiful blue cyanogen(mod)9 screen... How ...
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
Thread: Tried to Go to CM9, Now Stuck!
    Points: 1,894, Level: 25
    Level completed: 94%, Points required for next Level: 6
    250 Experience Points31 days registered100 Experience PointsTagger Second Class7 days registered
    Jaimie's Avatar
    33521
    47
    Ok, so I did it.... and everything seemed to have gone through quickly. When I reboot it comes to the beautiful blue cyanogen(mod)9 screen... How long should it be "stuck" there before its really STUCK? I've left it for 10 minutes then did a battery pull and same issue. Forgetting how to reboot into recovery also, have a feeling I'm going to need it...
    Points: 8,309, Level: 61
    Overall activity: 19.9%
    saul1991's Avatar
    37748
    1,294
    22 times
    Quote Originally Posted by Jaimie View Post
    If it gets stuck hold the home button and the powerbutton (on top) until the little android comes up and wipe cache and data
    Jaimie's Avatar
    33521
    47
    I tried that... but my options are different. text is blue
    Andriod system recovery <3e>
    Android Ssytem recovery utility
    reboot system now
    apply update from sc card
    wipe data/factory reset
    wipe cache partition
    I don't want to go back to factory!!!!! crap! crap! crap!
    Jaimie's Avatar
    33521
    47
    ** I tried the "wipe cache partition" with same problem. seems stuck at bootloader.. tried going to "apply update from SD" but it won't get to the download folder where the files it to retry it... I knew I should have waited till I got home. These things always looks so easy but then sh*t happens.
    Super Mod Team Lead
    Points: 36,067, Level: 100
    Overall activity: 100.0%
    Frequent Poster
    gbrinn's Avatar
    38696
    ECU College of Nursing
    14,596
    91 times
    Need Nemo Aeternam to chime in for an ADB recovery. He's good at this, rescued me a few times, lol. I got stuck at this exact spot and he pulled me out of it with ADB.
    Go ahead and download ADB to your computer if you don't have it. (Android Debug Bridge)
    "Master of Puppets I'm pulling your strings / Twisting your mind, smashing your dreams
    Blinded by me, you can't see a thing / Just call my name, 'cause I'll hear you scream
    Master / Master
    " - Metallica
    Super Mod Team Lead
    Frequent Poster
    gbrinn's Avatar
    38696
    14,596
    91 times
    Edit: Nevermind.
    Master / Master
    " - Metallica
    Points: 7,211, Level: 56
    Level completed: 31%, Points required for next Level: 139
    Overall activity: 27.8%
    1,340
    78 times
    Wipe the data, and cache. That's probably what's causing your bootloops. Don't worry, it's wiping data won't wipe CM9 off. I'm assuming you are boot looking because you didn't do the data wipe when you flashed.
    Sent from my secret shadow build...
    saul1991's Avatar
    37748
    1,294
    22 times
    reboot system now
    Wipe the data and cache in that menu use the volume up and down to go up or Down then the power button to click it then hit the reboot option
    Jaimie's Avatar
    33521
    47
    Got it working!! loving the look and feel. Camera (not focus) and vid recorder not working. I figured out my wifi settings, can't find the wifi widget. need to get Swype keyboard back.... Few other things but so far so good. Anybody know if/how to fix camera? is there a fix yet? I've read through so many forums today my eyes are killin me!
    Super Mod Team Lead
    Frequent Poster
    gbrinn's Avatar
    38696
    14,596
    91 times
    Camera focus works for me. Sometimes I have to restart the camera, though. Video camera, try the LG camcorder on lowest setting. I think that's been what's working for most, so far.
    Sent from my DROIDX using Xparent Cyan Tapatalk 2
    Master / Master
    " - Metallica
  1. Contacts stuck in Droid X Stuck on Motorola Logo
    By bsamuels22 in forum Droid X Rescue Squad
    Last Post: 01-05-2012, 07:24 PM
  2. HELP! Stuck on A2.2.1
    By havb in forum Gingerbread Help
    Last Post: 11-03-2011, 02:16 PM
  3. Zip (STUCK)
    By brighama in forum Droid X RS Guides
    Last Post: 10-08-2011, 04:47 PM
  4. Can't he the TBH. 602 to stuck
    By Newber in forum Droid X Help
    Last Post: 08-26-2011, 03:43 PM
  5. Help stuck after SBF
    By mespinosa88 in forum Droid X Rescue Squad
    Last Post: 07-05-2011, 05:53 PM
caynogen mod long boot xoom
cm9 stuck on splash screen
cyanogen mod 9 screen stuck
cyanogenmod 9 hangs on boot
cyanogenmod 9 stuck on boot screen
cyanogenmod 9 stuck on splash screen
cyanogenmod stuck on splash screen
cynogenmod 9 update boot time
galaxy s3 stuck on cyanogenmod boot screen
galaxy s3 stuck on cyanogenmod screen
