update failure
This is a discussion on update failure within the Droid X Help forums, part of the Droid X Discussion category; I am trying to update my dx System version: Verizon.2.3.340.MB810.Verizon.en.US Android version: 2.2.1 The update it is trying to download and install is 4.5.605.en.US Seems ...
Results 1 to 7 of 7
Thread: update failure
    Points: 1,998, Level: 26
    Level completed: 98%, Points required for next Level: 2
    Overall activity: 1.4%
    PolarBear's Avatar
    15311
    112
    update failure
    4.5.605.en.US
    Seems to download alright but after the reboot it says that it failed.
    Now I had it rooted with Z4 but unrooted it before doing the update.
    Is there something I am missing ?
    Points: 22,593, Level: 93
    Level completed: 25%, Points required for next Level: 757
    Overall activity: 39.0%
    Nemo aeternamn's Avatar
    37333
    Mo-ab
    7,636
    134 times
    While you were rooted... did... you modify any of the system files? Debloat?
    If so that's why the update is failing
    Sent from my Galaxy Nexus using Droid X Forums
    Post Script:
    Nemo Aeternamn Wallpapers
    PolarBear's Avatar
    15311
    112
    I did rename some .apk's to .bak however I renamed them back and then removed root via Z4 before attempting to update.
    ::EDIT:: Forgot to mention that after restoring the apk's, I went to google play and updated all the apps before removing root.
    Points: 8,295, Level: 61
    Level completed: 49%, Points required for next Level: 155
    Overall activity: 18.9%
    saul1991's Avatar
    37748
    1,292
    22 times
    Can't you just sbf to gb .605?
    PolarBear's Avatar
    15311
    112
    Quote Originally Posted by saul1991 View Post
    Not sure where to get a valid version of .605 and then not sure how to install that. Would it cause me to lose things like a phone reset ?
    saul1991's Avatar
    37748
    1,292
    22 times
    Quote Originally Posted by PolarBear View Post
    Yeah it would reset your phone like the day you got it but this time with the .605 update. If you don't want to erase everything don't do it.
    Points: 7,198, Level: 56
    Level completed: 24%, Points required for next Level: 152
    Overall activity: 28.2%
    1,340
    78 times
    SBF would be best bet, way easier. I've never liked the "unroot" option given by rooting tools. Even if you changed your extensions back its pretty likely you will continue to fail it regardless because the update . zip checks EVERY file in the system directory and if one fails the whole update does. You have two different options IMO:
    SBF to .340, this should allow you to (hopefully) retain data, then the system would be fresh and you can go from there.
    However, tbh I've always avoided OTA updates like the plague. There's much easier ways to do it and get more benefits. In your case as your on Froyo, I'd recommend re-rooting. Backup all your stuff with Titanium, Google servers, etc. Then just flash the 15p AIO, factory reset before flash, boot up, and restore apps/re-sync Google, and enjoy the win (flashing a .605 AIO pre-rooted with the .15p radio and updater blocked for none of that .621 monkey business.)
    EDIT: Almost forgot. 15p AIO is in the link in my sig.
    Sent from my secret shadow build...
  1. Replies: 3
    Last Post: 11-15-2011, 03:23 PM
  2. Gingerbread OTA update failure
    By calexsjr in forum Droid X Help
    Last Post: 08-02-2011, 10:39 AM
  3. Failure to update drivers on PC
    By Intimdtr77 in forum Droid X General Discussion
    Last Post: 02-05-2011, 01:25 PM
  4. Update.zip failure please help.
    By Les in forum Droid X Rescue Squad
    Last Post: 01-04-2011, 03:20 PM
  5. Latest OTA update failure
    By xxfallacyxx in forum Droid X Help
    Last Post: 12-16-2010, 02:53 PM
droid htc incredible binary legacy update failure
droidx ota
how to update droid x
ota updates after root
pre root 605 download
update droid x july 2012
