Restoring Backup is Hanging
This is a discussion on Restoring Backup is Hanging within the Droid X Help forums, part of the Droid X Discussion category; I have a DroidX that has been working very well. It is rooted with the DoomLord one click root tool. I use GoLauncher and had ...
Results 1 to 1 of 1
Thread: Restoring Backup is Hanging
    Points: 814, Level: 15
    Level completed: 14%, Points required for next Level: 86
    Overall activity: 0.7%
    Charley's Avatar
    46774
    Aug 2011
    29
    Restoring Backup is Hanging - Clockworkmod Rom Manager
    I have a DroidX that has been working very well. It is rooted with the DoomLord one click root tool. I use GoLauncher and had everything setup and running pretty smoothly. Then Go went a little blinky on me and I restored my Go Launcher backup from a few days ago. That did not work and put me on some general generic version of Go Launcher.
    OK. I'll just use Rom Manager to reboot into recovery and install that backup from June 30. Rom Manager starts and I choose the reboot into clockwork recovery for manual management. Then I choose Restore and the June 30 backup event. It takes off after doing the check sum. I have the message Restoring System and that seems to complete as it then provides another message of Restoring Data. This is where it has hung and seems to have stopped, showing the dropbox application as the one it is trying to restore data for. No advance for 10 minutes now.
    Anyone have an idea as how I should proceed. this is my second session trying this in the last hour. It hung and seemed frozen in the same spot, dropbox data, in the first attempt. I did a battery pull and reboot to get out of that one. However that required that I go through the full setup and sync route, then was going to have to re-install a bunch of apps. At that point, I decided to only reinstall Rom Manager from the market and try to use Clockwork Restore again. Still stuck.
    Suggestions appreciated.
  1. My Backup - Need help restoring
    By fsand in forum Droid X Help
    Last Post: 07-24-2011, 12:25 AM
  2. Currently stuck at a restoring backup
    By steveo676 in forum Hacking Help
    Last Post: 03-23-2011, 09:20 PM
  3. Restoring Nandroid backup
    By jayz66 in forum Hacking Help
    Last Post: 01-26-2011, 06:08 PM
  4. Backup and restoring backups
    By skennelly in forum Hacking Help
    Last Post: 01-18-2011, 10:23 AM
  5. restoring backup on new phone
    By falcon9094 in forum Droid X Rooted Issues
    Last Post: 01-09-2011, 02:43 PM
android full restore stuck
android hanging on restore
android how to know if restore is hung
android restoring system hung
clockworkmod stuck on restoring data
doomlord root setup
galaxy nexus full restore hangs
galaxy nexus restore backup hangs
go launcher backup restores one at a time
nexus 7 full restoration hangs
