Need fix for repeated Gmail Login Failures
This is a discussion on Need fix for repeated Gmail Login Failures within the Droid X Help forums, part of the Droid X Discussion category; I changed my Gmail password weeks ago. For some reason, my DroidX never got the memo. Every day I will receive notice of a Login ...
Thread: Need fix for repeated Gmail Login Failures
    Points: 4,989, Level: 45
    Level completed: 20%, Points required for next Level: 161
    Craig225's Avatar
    35008
    364
    I changed my Gmail password weeks ago. For some reason, my DroidX never got the memo. Every day I will receive notice of a Login Failure. I re-enter my new password, as I have done several times already. No dice. It doesn't recognize it. Then I reboot and everything is fine. Until the next Login Failure, maybe in a day or two. How do I fix this?
    Points: 1,276, Level: 19
    Level completed: 76%, Points required for next Level: 24
    rnelson330's Avatar
    41936
    I am having the same problem the two days but i haven't chanded that password.
    Quote Originally Posted by Craig225 View Post
    I was having the same problem on my DroidX for a few months after changing my pw. The bigger problem for me was that sync wasn't happening (for Gmail and G. Calendar) and I thought the two symptoms were related. Of course, the message doesn't say which application(s) are having login failures, but I guessed it was related to the phone's mail and calendar sync (Google's). Gmail sync worked whenever I sent myself an email from my phone, so I did that repeatedly for awhile. About a month ago I tried the instructions at the Google support pages for "Problems syncing Gmail on Android" (https://support.google.com/mail/bin/...727&page=ts.cs). That fixed the sync problem for Gmail (except once a few days ago when I had to send myself an email again to wake up the sync). However, the "login failure" message continues occasionally and Google Calendar sync continued to be a problem. That is, things would sync from the web to the phone but not from phone to web. So a few days later I finally followed the Google Calendar sync instructions for "Problems with sync" (Problems with sync - Google Mobile Help) and that appears to have fixed my calendar sync problems. Though I still get the login failure messages sometimes, the applications and their sync seem to be working. (Maybe the sync retries periodically and only fails some of the time.) I have not been rebooting in response to the login failures; I just let them pass by. I did do reboots while following the fix instructions linked above. I don't reboot often in general (maybe should do so prophylactically more often).
    I'm going to start recording when I get the login failure messages so I have better data to report in future (e.g., about the continuing frequency). Of course, since the message disappears on its own in a couple seconds, it could be happening much more often than I'm aware of (while I'm not looking at it).
  1. Gmail not syncing read messages with gmail server?
    By Coronado is dead in forum Droid X General Discussion
    Last Post: 02-05-2011, 01:26 PM
  2. Market purchase charge failures?
    By Getsome122 in forum Droid X General Discussion
    Last Post: 01-21-2011, 01:57 AM
  3. Replies: 2
    Last Post: 01-14-2011, 07:31 PM
  4. Replies: 2
    Last Post: 12-29-2010, 05:35 PM
  5. froyo 2.2 failures
    By cw0974 in forum Droid X Help
    Last Post: 08-21-2010, 01:40 PM
android gmail login failed
android gmail login failure
android gmail sign in failed
galaxy s3 gmail sign in failed
gmail login failed android
gmail login failed on android
gmail sign in failed android
gmail sign in failed galaxy s3
news
sign in failed gmail android
