DroidX stuck at M, not charging?
This is a discussion on DroidX stuck at M, not charging? within the Droid X Help forums, part of the Droid X Discussion category; Hey all, Need some help. Yesterday I tried to boot my phone up and it's stuck at the M logo (red circle, white M). I've ...
Results 1 to 10 of 10
Thread: DroidX stuck at M, not charging?
    Hey all,
    Need some help. Yesterday I tried to boot my phone up and it's stuck at the M logo (red circle, white M). I've tried holding home + power and that doesn't do anything. Now it only comes up with the M logo if it's plugged into the wall and it still just sits there. It doesn't seem like the battery is charging either and I'm not sure if that's an issue with the battery or the phone. I didn't root my phone nor change anything aside from a few widgets, but that was like...two years ago when I first bought it. Likewise I didn't change or do anything prior to this, it just wouldn't boot up. I had some slight freezing problems prior to the phone not working and I noticed that it was a bit slower though. I'm not sure of the exact version I was on, only that it was the most recent one when I checked a month or two ago. I also checked around the forums a bit, but most of the advice seemed to try starting the phone with the home+power method and scrolling through the options there. Any suggestions for what else I can do?
    Thanks in advanced
    Points: 7,324, Level: 56
    Level completed: 87%, Points required for next Level: 26
    Overall activity: 24.2%
    1,341
    78 times
    You need to SBF it. Since you were on the latest you need to use the .621 SBF, and use RSD Lite. You may get the SBF file from here:
    .621 SBF Posted
    And use RSD Lite. If you've never done this, check here for files needed and a guide:
    [Guide] Flashing Droid X SBF - Droid X - RootzWiki
    Thanks for the reply, the problem is that I can't enter bootloader mode at all. If I plug the phone into the wall charger the M logo pops up right away so I can't get to it that way (even holding the buttons while it's on the M screen) and if it's plugged into my the green led is on but it won't power up in bootloader mode either.
    Edit: Ok, well I just got into it but it said 'battery low cannot reprogram' so I'm going to go ahead and order another battery, see if that charges / holds a charge and flash it and hope that it works.
    1,341
    78 times
    Quote Originally Posted by lesamourai View Post
    Power it in bootloader prior to plugging in. Make sure you are pressing and holding volume down and camera prior to pressing power button. If you plug it in prior to going into the bootloader the phone may attempt to boot first which means you can't get to bootloader.
    Sent from my Wiz Wiz MIUI!
    .621 SBF Posted
    So I got a new battery and was able to power up in bootloader and sbf it. After I did that I tried to enter stock recovery since it was still bootlooping and even though I was holding both the power and home buttons it wouldn't go into recovery mode. Any ideas what else I might try?
    Points: 257, Level: 5
    Level completed: 14%, Points required for next Level: 43
    d_silk1979's Avatar
    59944
    Jul 2012
    same
    Im having the same issue. Phone froze so i powered down. After that i can get to the bootloader but not the recovery mode. Other than that i just sit on the red m until my battery drains. I havent sbf'ed because i dont see why id need to. My phone was fine and stock, then bam the red m. Strange.
    Points: 18,305, Level: 85
    Level completed: 91%, Points required for next Level: 45
    Overall activity: 95.4%
    6,302
    139 times
    Sounds fishy... but at this point it sounds like a SBF is your only option if you can't access stock recovery.
    1,341
    78 times
    Yeah or you may also be having hardware buttons issues. Does it immediately boot to bootloader upon power on? Or is that the only live mode you can access and its bootlooping if you try just powering straight on?
    If its booting straight to bootloader on a standard cold boot then you will need to SBF, for sure. I almost wonder if its a hardware issue if you were truly doing nothing and then it just froze to bootloader, but the first real test to do is SBF it.
    Secondly if you are able to get past the bootloader but hardware keys are not allowing you to get to stock recovery you can try attaching a usb cable and if you have a working adb setup run "adb reboot recovery" (without the quotes) in terminal/command line from the PC in your adb directory and it should force it to recovery if there's nothing corrupted on the recovery partition and its booting far enough to be recognized by adb.
    i just bought a brand new battery from amazon.com...
    i turn it on and it says LIBERTY
    I cant get passed this screen at all, i even factory reset it.
    does SBF-ing work for that screen too?
    6,302
    139 times
    So you've tried going into stock recovery and wiping data then rebooting? As long as you can boot into bootloader (hold camera button, vol down and then power) then yes a SBF will work fine assuming the battery is charged enough. If you're bootloader says "Battery Ok" then you are good to go.
  1. Replies: 1
    Last Post: 11-30-2011, 10:12 PM
  2. Anyone else having trouble with a droidx while charging?
    By KarmicTreasures in forum Droid X Help
    Last Post: 07-23-2011, 09:16 PM
  3. droidx bootstrapper charging for update after purchase
    By rickkane in forum Droid X Apps
    Last Post: 01-08-2011, 12:58 PM
  4. Replies: 3
    Last Post: 12-05-2010, 05:37 PM
  5. Charging a bricked DROIDX
    By ofrhythm in forum Droid X Rescue Squad
    Last Post: 10-16-2010, 11:56 AM
droid x Stuck at M
droid x battery not charging
droid x no charging screen
droid x not charging
droid x not charging stuck on yellow
droid x stuck on M
droid x stuck on m logo
droid x stuck on red m
droid x stuck on red m logo
phone stuck on red m turn on
