stupid question (vibrating text alerts)...
This is a discussion on stupid question (vibrating text alerts)... within the Droid X Help forums, part of the Droid X Discussion category; hey all, so can anyone make the DX vibrate for all notifications, without having to set everything to silent/vibrate mode? like for instance, on my ...
Thread: stupid question (vibrating text alerts)...
    Points: 1,231, Level: 19
    Level completed: 31%, Points required for next Level: 69
    KDogg's Avatar
    575
    29
    hey all,
    so can anyone make the DX vibrate for all notifications, without having to set everything to silent/vibrate mode? like for instance, on my old LG dare, i'd set it to ring/vib for calls, and only-vibrate for texts, without having to put the phone into vibrate-all mode or anything like that. does that make sense? thanks in advance.
    Moderator
    Points: 1,905, Level: 26
    7 days registeredThree Friends250 Experience PointsTagger Second Class100 Experience Points
    Sam's Avatar
    Dirty Dirty
    328
    11 times
    for every app (that would typically include a vibrate function) there will be an option in settings to set it to vibrate with the tone you selected. for example, if you want it to vibrate when you get a text, go into your messaging app and then settings. i think you can do that with gtalk and gmail too, you'd just have to check. the exception is the phone... to do the phone, (from your home screen) hit your menu button and then settings, then sounds and there should be a check box in there
    Respect is rule #1
    Uughh.. That is my professional opinion.
    KDogg's Avatar
    575
    29
    Quote Originally Posted by Sam View Post
    awesome, that did it, each one had a toggle switch. thanks!
    Points: 2,744, Level: 31
    Level completed: 96%, Points required for next Level: 6
    Veteran1 year registered3 months registered31 days registered7 days registered
    kuku202's Avatar
    70664
    Feb 2015
    I have tried to set up corporate activesync thru the native app but no joy. I downloaded "Touchdown" and it works fine. I would still prefer to access thru the phone OS instead of using an outside app.
    Usman
  1. DROID X - Custom ringtone for Text Messages
    Last Post: 07-15-2010, 02:12 AM
  2. DROID X - Text Entry, Swype, Speech to Text
    Last Post: 07-15-2010, 01:36 AM
  3. DROID X - Text Messaging (MMS, SMS)
    Last Post: 07-15-2010, 01:30 AM
  4. Car Charger question
    By supahrob in forum Droid X General Discussion
    Last Post: 07-11-2010, 10:53 AM
  5. Launcher Pro question
    Last Post: 07-10-2010, 11:44 PM
droid x2 text message vibrate
droid x2 vibrate for texts
droid x2 vibrate on text
how to get droid x to vibrate for texts
how to get droid x2 to vibrate
how to make a droid x vibrate for text messages
how to make droid x2 vibrate
how to make droid x2 vibrate for texts
how to set droid x2 to vibrate
how to set droid x2 to vibrate on text
