Hi, I recently purchased a completely stock used Droid X. It is my first smartphone. The phone information is:
System Version: 4.5.621.MB810.Verizon.en.US
Android Version: 2.3.4
Baseband Version: BP_C_01.09.15P
Kernel Version: 2.6.32.9-g1282440 mcbk83@il93lnxdroid08 #1
Build Number: 4.5.1_57_DX8-51
What I want to do with this phone is to remove the following applications: Amazon Kindle, Amazon MP3, Verizon Apps, Blockbuster, Books, Browser, City ID, My Verizon Mobile, Quickoffice, Skype Mobile, V Cast Media Manager, Voicemail, and VZ Navigator.
All of those apps I will never use but they are running and taking too much system ram. Every time I load twitter or browse the web with Dolphin Browser, upon exiting, the home screen needs to reload because the system shut it down to free ram. A task manager will usually list those apps above as running and together they take a significant amount of ram.
So far I have found that for them to be removed, I will need to root the phone. Upon googling directions to do this, I've found that my system version is very new and there isn't very good direction on how to do it. Every guide I have found is out of date. By searching Google for results in the past 2 months, I did find some guides. But they give directions for how to re-root the phone for people who were rooted but installed the .621 update. This just isn't very helpful to me. Most of these guides assume they already have a custom bootloader installed, recovery systems, system backups or nandroids, and the knowledge of how it was done last time.
I need directions on how to do it when starting from square one with version .621. I don't know how to install a custom recovery that will allow me to create a backup before attempting anything in a lot of these guides, and to get a custom recovery it seems the phone needs to be rooted first. But the phone was never rooted and so it doesn't have that recovery or bootloader that allows people to root their .621 phones.
Please help. Thank you to all who read this.
EDIT: For those who may find this post via Google and the like. Here's how it's done:
You only need 2 files and 1 android market app.
- Rooting the Droid X flashing a Milestone X .604 image:
- Download 1KDStaz_MX_4.5.604.iso (Milestone X 4.5.604 Gingerbread), burn the .iso to disk, then boot this disk
- Flash the Milestone X .604 SBF via 1KDS ezSBF Live Disc using the directions provided on the disk
- Root the phone using the method provided on the 1KDS ezSBF Live Disk
- Boot the Phone.
1. Go to the play store and download "Droid 2 Bootstrap." for your Droid X for $2.99 Edit: Look around, there may be a free recovery available.
2. Open the app, install the recovery (Bootstrap Recovery), then boot the recovery (Reboot Recovery) to verify it works
- Download 4.5.621 Stock Rooted Deodexed zip file and place it on your SD card.
1. Boot into the recovery from Droid 2 Bootstrap************************************************** **************************************************
2. Wipe all the catches and format the System
3. Flash the Zip file
4. Reboot the phone. You now have a stock rooted Droid X.
3Likes
