Droid X battery draining very quickly with little use + phone sometimes getting warm
This is a discussion on Droid X battery draining very quickly with little use + phone sometimes getting warm within the Droid X Help forums, part of the Droid X Discussion category; I spent several days trying to figure out why my Droid X was draining my battery so quickly, with little use and even overnight -- ...
Thread: Droid X battery draining very quickly with little use + phone sometimes getting warm
    I spent several days trying to figure out why my Droid X was draining my battery so quickly, with little use and even overnight -- it had never done this before. It was also sometimes getting warm -- also something that I had never noticed before. I was unsuccessful in finding a direct answer from the internet, but I did get some ideas and kept fiddling until I was able to a solve the problem ! I basically did two things -- not sure if one or both got things back to normal, but I will list both of them. I noticed that from settings / battery and data manager / battery usage that Yahoo Messenger (which I sometimes use) had received a very high amount of Data -- even though I wasn't using it. I then opened Yahoo Messenger and realized that I was automatically signed in, but did not know it... so I signed out ! The second thing I did is that I went to settings / battery and data manager / data delivery and I turned the Background Data OFF (unchecked) ! After doing both of these things the battery time was back to normal, and phone never gets warm ... so I wanted to share my happiness in getting the battery drainage problem solved and hope this post may help someone else.
    Banned
    Points: 9,438, Level: 65
    Level completed: 30%, Points required for next Level: 212
    DroidlynnXDoes's Avatar
    56858
    Mar 2012
    In a world that doesn't
    3,118
    16 times
    I will have to try that. Although my X gets warm quite often, it doesnt get too warm, but when it does ive put it on me when I dont feel well to help with the pain and doscomfort. But it doesnt to too warm to have on me dont worry so it wont hurt me.
    Standing in the shadows of love with my DROIDX/ Droid Shadow
    Banned
    56858
    Mar 2012
    3,118
    16 times
    Quote Originally Posted by DroidlynnXDoes View Post
    This is weird, but my X cools off after its been on me for a little while
    Thank you for posting that information! It was great to see the answer without the question
    Points: 967, Level: 16
    Level completed: 67%, Points required for next Level: 33
    spitfire13's Avatar
    49924
    Oct 2011
    I'll try that. I usually have to keep yahoo messenger on because I get my job hours posted that way but I'll try the settings thing. My phone drains so fast it is iediculous. I use 4 batteries and go through them all each day. I even have one extended and it doesn't last 4 hours. My batteries sometime are way below 70 over night just sitting there.
  1. Droid X battery draining fast.
    By Mudig in forum Droid X Help
    Last Post: 04-10-2012, 10:05 AM
  2. HOW TO: Charge your battery... quickly! (and one problem)
    By lvsteven in forum Droid X2 Support
    Last Post: 07-15-2011, 12:24 AM
  3. Contacts are draining all of my battery
    By kami Kali in forum Gingerbread Help
    Last Post: 05-09-2011, 09:04 PM
  4. My Droid X has a tendency to get very warm.
    By Amaria in forum Droid X Help
    Last Post: 05-08-2011, 08:59 AM
  5. Battery dies too quickly
    By SueKym in forum Droid X Help
    Last Post: 02-19-2011, 08:55 PM
droid battery drains too fast
droid mini battery drains fast
droid ultra battery runs out quickly
droid x battery
droid x battery drain
droid x battery draining quickly
droid x2 battery dies quickly
droid x2 battery drains fast
why does my droid x battery die so fast
why does my droid x2 battery die so fast
