Do something special to boot animations?
This is a discussion on Do something special to boot animations? within the Droid X Help forums, part of the Droid X Discussion category; I am trying to change the boot animation on my X. I have pushed bootanimation.zip to both /data/local and /system/media using Terminal Emulator, adb push, ...
Results 1 to 2 of 2
Thread: Do something special to boot animations?
    Explodee's Avatar
    7164
    8
    I am trying to change the boot animation on my X. I have pushed bootanimation.zip to both /data/local and /system/media using Terminal Emulator, adb push, and root explorer. All I'm getting is a black screen after the M logo. I was able to successfully change it to the red rage boot animation by pushing it to /system/media but the sizing was off and it didn't looks so good. But I have tried 2 different BA's and get the black screen. Do I need to modify something to make it compatible with the X? Below are the 2 I was trying to push.
    [Boot Animation] Qteknology's Splash Inverted v2 (Updated 2010-3-3) - xda-developers
    [Boot Animations] & [Live Wallpapers] Nexus Holiday in a variety of colors - xda-developers
    PS I have rooted 2.1
    Points: 1,675, Level: 23
    Level completed: 75%, Points required for next Level: 25
    250 Experience Points100 Experience Points31 days registeredTagger Second Class7 days registered
    StuntinX's Avatar
    8837
    47
    Your problem is most likely that you have not renamed the .zip file. It must be renamed bootanimation.zip and have it placed on the ROOT of your sdcard then run your terminal emulater with:
    su
    cp /sdcard/bootanimation.zip /data/local/
    reboot
    As for the resizing... Open into the bootanimation.zip then into the desc.txt file and you will see:
    xxx xxx xx
    p 1 0 part0
    p 0 10 part1
    Change that to:
    480 854 xx
    p 1 0 part0
    p 0 10 part1
    The last two "X"s represents the frames per second and you should leave the original value alone... I hope this helps and let me know if you have anymore problems, maybe i can help
  1. Special Characters Not Honoring Spacebar?
    By the_Fiddler in forum Droid X Help
    Last Post: 05-14-2011, 04:11 PM
  2. X won't boot past M logo
    By fragar in forum Droid X Help
    Last Post: 11-17-2010, 07:53 PM
  3. Droid X Stuck at Boot
    By James in forum Droid X Hacks
    Last Post: 09-22-2010, 12:14 PM
  4. What to do with Droid X on it's first boot?
    By omnicious in forum Droid X Help
    Last Post: 07-23-2010, 11:24 AM
  5. Wirefly.com special pricing for the X
    Last Post: 07-15-2010, 05:21 AM
push boot animation terminal droid x
