Unable to upload phone book to Panasonic KX-TG7745 Link2Cell phone
This is a discussion on Unable to upload phone book to Panasonic KX-TG7745 Link2Cell phone within the Droid X Help forums, part of the Droid X Discussion category; We recently disconnected our home landline and purchased a Panasonic KX-TG7745 telephone system with Link2Cell functionality. We are not that tech savvy, but we managed ...
Thread: Unable to upload phone book to Panasonic KX-TG7745 Link2Cell phone
    We recently disconnected our home landline and purchased a Panasonic KX-TG7745 telephone system with Link2Cell functionality. We are not that tech savvy, but we managed to get 2 Droid X cell phones connected to the Panasonic system and we can answer and make calls with the Panasonic handsets. We followed the directions in the Panasonic User Guide to upload the phone book from the cell phones, but have not been successful. We selected the "Auto" command on the Panasonic and the Droid X makes a tone sound indicating that it is connected. The Panasonic handset displays a message "Transferring phone book", but after a minute or so, displays an error message: Error!!
    We tried the "Manual" command, but we don't know what to do on the cell phone to push the phone book to the Panasonic. In the Droid X Contacts list, we found an Import/Export option, but it was only to/from an SD card, not an external device. And I didn't see anything in the Bluetooth options that seemed to pertain to the issue.
    Any help will be greatly appreciated!!
    Thanks.
    Points: 22,755, Level: 93
    BHuber09's Avatar
    34670
    Atlantis
    6,636
    446 times
    Ok im not sure how to do this but i have an idea.
    What you can do is go into contacts and do the import export option. Export it to sd card. Then connect your phone to your computer and open up files on your droid X and there will be a 00001.vcf file. That will be your contacts.
    So i have no idea what you are trying to do at all but now if you can get the file from your computer to Panasonic system then youll have the contacts.
    Or maybe just enter them in manually but i pressume you wouldnt want to do that haha.
    No one else helped so i figured i would throw out my idea.
    FreeMyMoto!!!
    If you need help PM me!!!
    Bhuber09 - Thanks for the suggestion. My son came by today and figured it out -- during the auto upload, the Droid X made a tone sound. I thought that meant it was connected to the Panasonic; what I didn't realize was that the Panasonic was sending a request to the Droid X to download the contacts. My son looked in the Droid Notifications and clicked OK on the request and VOILA! the contacts started downloading. So it was user error - DUH!!
    Same problem
    What is happening is that as soon as you select auto, the bluetooth connection drops.
    Panasonic is clueless and says the phone is not compatible (I have an HTC M8)
  1. phone book apps?
    By billhansen2010 in forum Droid X General Discussion
    Last Post: 07-04-2011, 03:43 PM
  2. Cruser2 Phone Book Integration
    By 4037dx in forum Droid X Help
    Last Post: 01-01-2011, 07:36 PM
  3. importing the droid phone book to the car
    By ravis in forum Droid X General Discussion
    Last Post: 08-09-2010, 03:00 PM
  4. Replies: 0
    Last Post: 08-06-2010, 02:13 PM
  5. Replies: 0
how to copy contacts from iphone to panasonic cordless home phone
link 2 cell contact list
link2cell phonebook transfer
panasonic cordless phone book transfer
panasonic link to cell compatibility galaxy s4
panasonic phonebook transfer
samsung galaxy s3 link to cell phone book export to landline
syncing contacts from samsung gs 4 to a panasonic link to cell
transfer phonebook from phone to phone panasonic
transferring contacts from galaxy s4 to a panasonic link to cell
