This is a screenshot of the vpn settings I need to fill out so my MMS may work. I'm on the gummy 1.0.2 and I have c-spire as my carrier.
Sent from my DROIDX
This is a discussion on APN help? within the Droid X Help forums, part of the Droid X Discussion category; This is a screenshot of the vpn settings I need to fill out so my MMS may work. I'm on the gummy 1.0.2 and I ...
Sent from my DROIDX
In case you haven't found the answer to thus yet, what you need are the APN settings. You can open voice dialer and say "open APNs" and you'll get into it. Create a new APN called CSpire or something and change the MMSC field to say http://pix.cellularsouth.com/servlets/mms then save it. It wouldnt hirt yo delete any other APN settings in the list as well. Hope this helps!
What about the rest of the settings?
Sent from my DROIDX
Sent from my DROIDX
Change the APN type to mms. If it still doesn't work properly change the top two lines from "CSpire" to "CDMA" and "1" some phones are finicky about naming.
What do you mean by "1"?
Sent from my DROIDX
I still can't get it to work man. Can you take a screenshot of the last part of your apn settings .
Sent from my DROIDX
This is the very bottom of the file. Do you have ANY other APNs still in your APN list or is the one you've created the only one?
It doesn't show any other apn settings. How are you accessing your apn settings? I'm using the app apn shortcut.
Sent from my DROIDX
