Verizon is evidently showing an old Android build (or just guessing, maybe). By pressing exact locations on my screen when compared to the Verizon shots, I was turning on and off silent mode...
Below is my About Phone for reference, since they change the menus with every Android update:
Press menu button then settings:
This is what the menu looks like by default with this version of Android:
Flip the screen to scroll all the way to the bottom, and applications *should* be the top selection
(the only menu option NOT shown in these 2 screenshots is Accounts, which is between Location & Security and Applications):
Development is now closer to the bottom of the screen than the Verizon link I posted above shows:
Once you're on the Development screen, the 'buttons' are in the same locations as Verizon shows (5 images max per post) - see the last 2 images here:
USB Debugging Mode - DROID X by Motorola
1Likes
