Stuck in bootloader 30.04 after Moto Update
This is a discussion on Stuck in bootloader 30.04 after Moto Update within the Droid X Help forums, part of the Droid X Discussion category; Hello all, unfortunately I seem to be having a common problem. I just downloaded and installed the latest MOTO update for my DX. After/while installing, ...
Results 1 to 10 of 19
Thread: Stuck in bootloader 30.04 after Moto Update
    Points: 7, Level: 1
    Level completed: 13%, Points required for next Level: 43
    Tagger Second Class
    swimstar186's Avatar
    57568
    Hello all, unfortunately I seem to be having a common problem. I just downloaded and installed the latest MOTO update for my DX. After/while installing, the phone went to the bootloader screen 30.04, Err: A5,70,00,00,23. Now no matter what I do (i've pulled the battery numerous times, factory reset twice) the bootloader is all that my X will show when I power it on. I've talked to MOTO and they want me to send it in to them, but I'm skeptical and don't want to be without my phone for a month while they look at it. I've seen similar posts and people talking about SPF's and .621, etc but I have NO CLUE what all that means or what I have to do to fix this problem. Can someone please walk me through/explain exactly what I have to do? Thanks so much in advance!!
    Points: 7, Level: 1
    Tagger Second Class
    57568
    *SBF's
    RS Team Leader
    Points: 25,439, Level: 96
    Level completed: 9%, Points required for next Level: 911
    Overall activity: 15.1%
    popcenator's Avatar
    21238
    Omaha, NE
    8,255
    177 times
    If this happened while updating and you're on Verizon I'd take it to them and get a replacement. I'm not too sure an SBF is going to fix the problem.
    on the move..
    Points: 333, Level: 6
    Level completed: 66%, Points required for next Level: 17
    infazzdar's Avatar
    57226
    29
    You should definitely send it in.
    SBFing to .621 may fix your issue, but it would probably be better just sending it in.
    Sent from my Transformer TF101 using Tapatalk 2
    Points: 446, Level: 8
    Level completed: 92%, Points required for next Level: 4
    davecaldwell's Avatar
    47538
    Sep 2011
    My phone attempted the update tonight. While updating it displayed the same error message. I tried all the fixes I could find online and none of them worked. I took it to the Verizon store and the guy there tried them all too. He said my phone is toast. Luckily, I am within 2 days of my warranty running out so I'm getting a replacement (refurbished crap) phone, but hopefully it won't have all the probems I've had with this one. I absolutely LOVE the Android operating system, but this is my 2nd Android phone and I've had nothing but issues with both phones. One day, when I can afford it, I'm afraid I will be switching to an iPhone. The majority of my friends have the iPhone and not a single one of them has had an issue with the phone.
    Points: 17,755, Level: 84
    Level completed: 81%, Points required for next Level: 95
    Overall activity: 21.2%
    maybish's Avatar
    20852
    new jersey
    5,704
    251 times
    Wow what's happening? Everyones having the same issue!
    Points: 390, Level: 7
    Level completed: 80%, Points required for next Level: 10
    footer's Avatar
    49830
    Oct 2011
    9
    Dang. I just said OK to update and am getting this error. Not sure how patient I'm going to be for a fix and I doubt I'll be bringing it to Verizon.
    PS. This does not sound very good at all: https://community.verizonwireless.com/thread/772100
    P
    SS. This fixed it: Linux solution to your Windows/RSD lite problems
    I
    opted for this sbf: Android 2.3.3 System Version 4.5.605 (VRZ_MB810_4.5.605_1FF_01)
    Off to configure!
    Points: 8,909, Level: 63
    Overall activity: 43.1%
    1,340
    79 times
    Quote Originally Posted by footer View Post
    P
    I
    Off to configure!
    Its just failing out on the ramdisk update. I've heard of it a lot with the latest OTA. SBFing back to 605 should resolve these issues (as you mentioned).
    If your hard up for the latest you can always SBF to 621 to force it, but 621 comes with its own barrel of monkeys if you intend to root
    Sent from my unthrottled shadow AOKP!
    footer's Avatar
    49830
    Oct 2011
    9
    Thanks for that bit of wisdom Goose! I've only been playing with 605 for an hour or so and I'm already quite pleased with it (except for battery life?). I don't think I'll mess with 621. Happy to be up and running again after the near-brick-scare. Feels like a new phone again!
    Points: 3,895, Level: 39
    Level completed: 64%, Points required for next Level: 55
    Overall activity: 0.6%
    ems3's Avatar
    42619
    Jul 2011
    630
    I got forced into the update..... My x camera broke and the replacement had .621 installed.... I flashed the milestone .604 sbf and rooted with zergrush..... Then flashed wizards latest miui and im satisfied. Battery seems better than my old phone and a bit more responsive
    Check out my customized swypes .........http://www.droidxforums.com/forum/dr...keyboards.html
  1. nTelos X running the GB update, stuck at bootloader
    By smb1966 in forum Milestone X Support
    Last Post: 05-08-2012, 10:19 PM
  2. Flashed Deodexed All in 1 update now stuck at Bootloader! HELP?
    By budmonster in forum Droid X Rescue Squad
    Last Post: 07-20-2011, 06:57 PM
  3. Moto to unlock Atrix bootloader!
    By Fender890 in forum Off-Topic Discussion
    Last Post: 06-30-2011, 12:53 PM
  4. Replies: 13
    Last Post: 01-21-2011, 08:53 AM
  5. Stuck on Moto Logo, can't flash with bootloader
    By medicdanny in forum Droid X Rescue Squad
    Last Post: 12-21-2010, 08:49 PM
Droid x bootloader 30.04 error
bootloader 30.04
droid x 30.04 bootloader error
droid x bootloader 30.04
droid x bootloader 30.04 err
droid x error message bootloader 30.04
droid x stuck in bootloader 30.04
droid x stuck on bootloader screen
motorola bootloader 30.04
motorola droid x bootloader 30.04
