Help!
This is a discussion on Help! within the Droid X Help forums, part of the Droid X Discussion category; Hi I'm a total Novice when it comes to this but I'm having issues with my phone being VERY unresponsive and rebooting constantly. My phone ...
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Help!
    Points: 991, Level: 16
    Level completed: 91%, Points required for next Level: 9
    LeonidasMMA's Avatar
    21542
    5
    Help!
    Hi I'm a total Novice when it comes to this but I'm having issues with my phone being VERY unresponsive and rebooting constantly. My phone will freeze and then reboot. It's never consistant some times it will work for an hour or two then its back to Freeze and reboot.
    Can anyone help me with what may be wrong? Oh and my phone may be rooted....someone helped make my phone a wireless tether...but it doesn't actually tether anymore...I don't know why....HELP!
    Thanks,
    Joe
    Super Mod Team Lead
    Points: 23,961, Level: 94
    Level completed: 62%, Points required for next Level: 389
    Overall activity: 44.1%
    jwalz's Avatar
    34326
    7,603
    296 times
    What version are you running? You might have been rooted on froyo then took an update to gb... go to settings then about phone and what is the system version and android version
    21542
    5
    Of course my phone just died...I'll check it and then let you know thank you for helping!
    21542
    5
    System Version 4.5.605.MB810.Verizon.en.us
    Android Version 2.3.3
    Points: 3,188, Level: 34
    Level completed: 92%, Points required for next Level: 12
    Overall activity: 1.2%
    naidanirt's Avatar
    38544
    367
    hmmmmm i didnt really have a problem when moving from rooted froyo to stock gingerbread at all.... if i did i would have backed up my stuff to my sd card and then use Power+home and get into stock recovery and wipe my data....
    wiping data in stock recovery will usually fix stuff for me, but in my opinion it really isnt the answer to EVERYTHING.
    Points: 403, Level: 8
    Level completed: 6%, Points required for next Level: 47
    LDLloyd1's Avatar
    57699
    10
    OK so I am a total newb to all this... I am wanting to go back to completely stock, unrooted gingerbread (.605 update that comes automatically) after SBFing to froyo .340. I just activated my DX and the update is downloading now. Can I just take the OTA update to BG .605 and then go along from there, choosing to root or not? I've tried the whole "rooted .340 to to GB .602/.605 without SBFing" thing, but could never get it to work. Thus, I skipped all the signing in stuff and am hoping that I will be given the option to add my accounts and such after the update, assuming it will even work.
    I've just continually failed to flash to MiUi from froyo because of all the dead links and stuff in the posts out there (due to only being able to find legit MiUi SBFs for GB, but not being able to get back to GB to flash to GB MiUi versions that are rampantly available). I am getting to the point where I would rather deal with the GB bugs and be back to where I was a few days ago in legit mode, instead of trying and stuggling, eventually continually failing, to get back to where I was to try again with GB. I realized AFTER SBFing to froyo that all the posts on flashing MiUi and such were from like a year and a half ago, and have been uncomfortably stuck with froyo. Again, I want to remain stock, unrooted, up to the point of getting to GB .605, and go from there, if possible.
    I will more than likely need very detailed step-by-step instructions, if it's not too much to ask. Please help if you can, and thanks to the googolplexth power in advance!
    LDLloyd1's Avatar
    57699
    10
    Quote Originally Posted by LDLloyd1 View Post
    I'm bringing this up because all the methods of switching around require rooting, and I am positive that my issues arise because of my inability to grasp the concept in its entirety, which is obviously not good, since I'm required to follow directions to a T, without being able to find good downloads for the year-and-a-half-old files to move to my SD card for flashing/installing. Not being able to find all the files, and going through all the steps of installing multiple files, in order, booting into stock recovery, or CWM recovery, etc. is just confusing me to no end. I can handle the factory wipes/resets from factory recovery boot mode, but I'm like a goldfish with a short attention span, and all the copies of instructions out there, very seemingly outdated, not to mention NEVER seeming to be applicable to my exact situation, makes it like I'm trying to translate 14 languages in addition to English... and I'm only almost fluent in English. I almost finished the process that I am claiming is stock Froyo to stock GB, and it appears to have worked, as the app tray is now in the bottom right, instead of the center. I did just receive the confirmation, but am being hounded by .621 updates.
    From here, can anyone give me some pointers as to whether I should stick with any ROM options from .605, or if I should wait until .621 rooting is available? I'm asking this because I've read that it isn't rootable, but again, most of the posts aren't even from 2012.
    Again, thanks a bazillion in advance!
    Points: 6,294, Level: 51
    Level completed: 72%, Points required for next Level: 56
    jaguarxt's Avatar
    28099
    166
    9 times
    If you want root in the future then please stay away from 621. You can use Titanium Backup to freeze the updater.
    I use TeamBlackHat 4.5.605.Accurate_Battery (4.5.1_57_DX5-35). And I don't get the notification of 621. Which is one of several reasons that I like to use TeamBlackHat as the base before installing roms.
    Summary of Devices
    Device: Samsung Galaxy Note 2 (SGH-T889)
    Android Version: 4.1.1 Jelly Bean
    Build: JRO03C.T889UVALL4 (Rooted)
    Device: Motorola DROID X
    Android Version: 2.3.3 Gingerbread
    Build: 4.5.605.Accurate_Battery (Rooted)
    jaguarxt's Avatar
    28099
    166
    9 times
    Is rooting what you really want? And how long before your contract is ended.
    Summary of Devices
.621 bloat
4.5.605 droid x flash miui ics
Applanet
RootzWiki
adding vortex 621 to droid x directions
can ics be put on a droid x mb810?
droid x continuous reboot
droid x mb810 powers down and reboots continuously
easy fast root droid x .621
gummy rom apps to stay away from
miui 2012.4.5
vortex reloaded 621
vortex reloaded droid x install instructions
vortex reloaded install
vortex reloaded toolbox
