Droid X Camera issues
This is a discussion on Droid X Camera issues within the Droid X Help forums, part of the Droid X Discussion category; I am running Droid X 2.3.4 (4.5.621.MB810.Verizon.en.US) When I try to take a picture, my camera will either freeze/close and the picture will not get ...
Results 1 to 10 of 14
Thread: Droid X Camera issues
    Points: 2,664, Level: 31
    Level completed: 43%, Points required for next Level: 86
    Overall activity: 1.3%
    JCizzle93's Avatar
    39230
    87
    When I try to take a picture, my camera will either freeze/close and the picture will not get saved. Also when I go the "Files" -> "SD Card" -> "DCIM" -> "Thumbnails", it would close and go back to the App Drawer. I really want to know why this is happening and how I can prevent it from happening again.
    Thank You.
    Points: 22,113, Level: 92
    Level completed: 77%, Points required for next Level: 237
    BHuber09's Avatar
    34670
    Atlantis
    6,636
    446 times
    Try going into settings > applications > manage apps > all tab > scroll down to camera and select > then wipe cache.
    Then do that again for camcorder and gallery.
    FreeMyMoto!!!
    FreeMyMoto!!!
    If you need help PM me!!!
    Super Mod Team Lead
    Points: 23,961, Level: 94
    Level completed: 62%, Points required for next Level: 389
    Overall activity: 44.1%
    jwalz's Avatar
    34326
    7,603
    296 times
    If that does not work ^^^^ ... how many pics do you have in your gallery?
    JCizzle93's Avatar
    39230
    87
    Ill try that right now and in my Gallery its 28 in Camera Roll, 9 Folders, 189 photos and 11 videos.
    I tried to clear the cache but for "Gallery" and "Camera" there was no cache and the option wasnt clickable
    Points: 2,321, Level: 29
    Level completed: 14%, Points required for next Level: 129
    TriciaH's Avatar
    5723
    Central Texas
    65
    Recently had the same camera problem - freezing up the phone and not saving. We found Pandora Radio was the culprit in our case. Once that was uninstalled the camera returned to normal. Odd tho because Pandora had been installed for a while without camera problems. Have not reinstalled it yet to see if the problem repeats itself. We cleared the data, cleared the cache, tried an alternative camera app (which launched the camera but force closed), then after removing Pandora, the icon still froze the phone but the hard button did not. After two reboots icons and hard button all worked and the camera was back to normal. If you don't have Pandora disregard this post lol.
    JCizzle93's Avatar
    39230
    87
    hahahah yea i dont have Pandora, does anyone have any other solutions? =/
    Super Mod Team Lead
    jwalz's Avatar
    34326
    7,603
    296 times
    Sry reason why I asked is because I had a similar issue and reinstalled zips and nothing seemed to work then read a thread that if you delete some of the pics it works.. well it worked for me but I have over 300 lol
    JCizzle93's Avatar
    39230
    87
    oo yea ive deleted some pictures that i assume are "corrupted" but idk if that fixes it completely. I also noticed last time for the first time since the last OTA update, my phone would turn itself on again after being shut off >.> the OTA update was supposed to fix that.
    Droid X Camera Freeze
    I had same problem - camera and video camera freezing when I tried to use it on Droid X. The only thing that fixed it for me was to reset the SD card. I tried all the clear the cache suggestions but it did not work for me. Home > Settings > Storage > Unmount SD Card > (then u can) > Format SD Card. Camera and video camera work again. SD Storage Card is cleaned up - probably had some fragmented files on the SD card.
    JCizzle93's Avatar
    39230
    87
    Im not willing to format my SD card and lose everything on it lol i have some pics and files that I wanna keep.
  1. GPS and Camera issues 4.5.605
    By krzyshng in forum Droid X Help
    Last Post: 10-03-2011, 06:59 PM
  2. Camera Issues
    By skayte in forum Droid X Stock Issues
    Last Post: 10-01-2011, 07:49 PM
  3. Droid X Panorama assist camera issues (white flash/lines)
    By kferrari in forum Droid X Rescue Squad
    Last Post: 10-20-2010, 09:06 PM
  4. Camera Issues....
    By Chickiechicky in forum Droid X Stock Issues
    Last Post: 10-07-2010, 09:52 PM
  5. Camera Issues....
    By Chickiechicky in forum Droid X Rescue Squad
    Last Post: 10-02-2010, 04:02 AM
Droid Camera Problems
android 2.3.4 camera problems
droid x camera
droid x camera freezes
droid x camera freezing
droid x camera issues
droid x camera not working
droid x camera problems
droid x issues with camera
problems with droid x camera
