Is there an easy root method for .621?
This is a discussion on Is there an easy root method for .621? within the Droid X Help forums, part of the Droid X Discussion category; I would say the advantage of rooting. 621 directly is that you dont have to spend all that time sbfing and such. Either way will ...
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 23
Thread: Is there an easy root method for .621?
    Points: 17,983, Level: 85
    Level completed: 27%, Points required for next Level: 367
    Overall activity: 99.8%
    6,246
    138 times
    I would say the advantage of rooting. 621 directly is that you dont have to spend all that time sbfing and such. Either way will work fine.
    Points: 3,108, Level: 34
    Overall activity: 5.0%
    newmanx4's Avatar
    34469
    703
    27 times
    Quote Originally Posted by Einsteindks View Post
    If I rooted my X via the long milestone way, flashing the kernel back to Droid X, etc, would there be any advantage/reason to flash 621, then root using this new method?
    Sent from my DROID RAZR using Tapatalk 2
    There would be no reason to just do it. If you ever have to SBF .621 then just use the direct root method. That's my plan.
    Sent from my Black Iced X
    Points: 7,208, Level: 56
    Overall activity: 27.9%
    1,340
    78 times
    Quote Originally Posted by newmanx4 View Post
    Right. Unless you don't have Windows available or have issues with RSD Lite. If that is the case then the 604 SBF ISO is a good option as there is not a 621 ISO
    Sent from my jellybeaned AOKP GSIII
    Points: 1,215, Level: 19
    Level completed: 15%, Points required for next Level: 85
    Einsteindks's Avatar
    50523
    Oct 2011
    15
    Um, I thought there WAS an RSD file for 621?
    6,246
    138 times
    There is, I believe he was saying in the case that he didn't have a Windows PC readily available or was having issues with RSD.
    newmanx4's Avatar
    34469
    703
    27 times
    Yes, there is a .621 SBF for RSD. But there is no .621 ISO like the rest of the ISO's put together by 1KDS.
  8. #17
    50523
    Oct 2011
    15
    Ah. I stand corrected. Slight confusion of terms, is all.
  9. #18
    Points: 1,152, Level: 18
    Overall activity: 3.3%
    Aptiva's Avatar
    57621
    91
    I personally swear by the direct method that doesn't require .604 sbf.
    I've used it countless times without fault.
    I used the thumb drive method as well as using a vm
  10. #19
    Points: 4,577, Level: 43
    Level completed: 14%, Points required for next Level: 173
    SupraRZ95's Avatar
    32836
    186
    13 times
    Can I upgrade to
    . 621 then root then re flash my gummy ics so I can have the new radio?
    Fart Blood
    68 88 32 45 32 79 67 32 49 46 50 32 103 104 122 32 71 66 32 118 46 48 53 13 10
  11. #20
    6,246
    138 times
    You don't need.to take the 621 update to get the. 15 radio unless you want to. There are no real advantages to doing so and once you are on 621 you can't revert. Let me find you some links.
    First make a nandroid of the Rom you are on now.
    .15p flashable radio To update the radio you will have to SBF to Froyo and follow the instructions in the .15 flashable radio thread.
    The easiest way to SBF is to use Linux solution to your Windows/RSD lite problems (Download the Froyo Link and follow the instructions in the thread.) Root Froyo, Install bootsrapper, Flash The .15 Radio in CWM, SBF to Gingerbread .605 using 1kds only, (download from the link above.) Root GB, Install bootstrapper, and restore your Nandroid (or flash a new Rom if you wish,)
  1. [Root X] D3 1-click Root Method - Works on GB.602 and GB.605
    By ejgilkey in forum Gingerbread Development and Hacking
    Last Post: 04-10-2012, 11:06 AM
  2. [Root X] D3 1-click Root Method - Works on Droid X on 602
    Last Post: 09-21-2011, 11:48 AM
  3. Why RSD Lite rather than the Easy Linux Method?
    By justifi in forum Droid X SBF
    Last Post: 07-31-2011, 08:46 PM
  4. Why RSD Lite rather than the Easy Linux Method?
    By justifi in forum Gingerbread Development and Hacking
    Last Post: 07-31-2011, 01:44 PM
  5. Easy Root Market App - Single Button Root
    By TWong1200 in forum Droid X Hacks
    Last Post: 09-02-2010, 12:19 AM
.621 root method
1kdstaz mx
1kdstaz mx 4.5.604.iso
droid x .621 easy root
droid x .621 root
droid x 621 root
droid x 621 root method
droid x easy root
droid x root 621
easy root droid x .621
