my android market is not workind when the setps says "a server error has occurred retry or cancel and return to the previous screen" plz help mee because going crazy![]()
This is a discussion on Help me plzzzzzzz Help Me Plzzzzzzzzzzzzzzzz within the Droid X Help forums, part of the Droid X Discussion category; my android market is not workind when the setps says "a server error has occurred retry or cancel and return to the previous screen" plz ...
clear the data. should fix it
[h=1]SBF - Detailed Guide for Success - Windows 7[/h][h=1][HOW TO] Use Droid X Bootstrap[/h][h=1]All-In-One POST ROOT Thread[/h]
tell me how because I do not know ????
settings > applications > manage applications > "all" tab > scroll to market > click on it, then click "clear data"
settings>apps>play store>clear data
try "uninstall updates" from the same page, and reboot the phone
all it will do is get rid of the user data for play store. all you will have to do is log in again
i just cant keep up today. lol @harley
you could also try clearing cache in the same spot. all this does is wipe your temp memory. you wont lose ANYTHING
