Need some help fixing my root mistake!
This is a discussion on Need some help fixing my root mistake! within the Droid X Help forums, part of the Droid X Discussion category; Hey all, So today I just got my dad's old Droid X. He had already rooted it and flashed Cyanogen 7.1 on it. I wanted ...
Thread: Need some help fixing my root mistake!
    Hey all,
    So today I just got my dad's old Droid X. He had already rooted it and flashed Cyanogen 7.1 on it. I wanted something different so I tried to flash Liberty Beta 3 through ICS. So I can start up my phone in the bootmenu (press down volume button when the little LED flashes) I can do everything here, but can't for the life of me figure out how to get into a usable version of the phone. Whenever I reboot it gets to the Motorola "M" and stops there.
    Is this enough information to get help?
    Points: 7,195, Level: 56
    Level completed: 23%, Points required for next Level: 155
    Overall activity: 28.3%
    1,340
    78 times
    I'm a bit confused...
    You said he was on CM 7.1, which version? When you turn on the phone, the Moto logo, is it Red or White? I would assume red.
    I would assume you mean CM9, and EncounterICS. That is the only ICS or CM ROM that has the bootmenu implemented. (You are pressing Vol - at the blue LED, correct?)
    If that's the case the boot menu in that version is a bit b0rked and it doesn't always mount /system correctly, so its probably causing issues there. Get in to the bootmenu, go to Recovery -> Latest, get in Clockwork, perform a mini-SBF (wipe data/factory reset, wipe cache, wipe dalvik cache (its under advanced) and wipe /system (its under mounts and storage) and then reflash Liberty 3 v2; if you want to go to Liberty. If that fails you will need to SBF.
    Hey so I SBF'd hardcore and got it back to stock so I'm all set again. Thanks for the direction!
    Do a sbf its easy don't worry it will fix your problem
    Sent from my DROID2 using Droid X Forums
  1. Fixing GPS
    By 1jklange in forum Cyanogenmod
    Last Post: 09-23-2011, 02:31 PM
  2. Mistake or not
    By Anthony 23 in forum Droid X General Discussion
    Last Post: 02-11-2011, 02:37 PM
  3. Did us new droid owners make mistake
    By ARHicken in forum Droid X General Discussion
    Last Post: 12-30-2010, 04:57 PM
  4. thinking i made a mistake
    By joedirt9035 in forum Droid X General Discussion
    Last Post: 08-24-2010, 12:57 PM
  5. /preinstall folder deleted by mistake...
    By johnzz4 in forum Droid X Hacks
    Last Post: 08-08-2010, 01:20 AM
droid x fix root
droid x root mistake
fix my android root mistake
fix my root
flashing cm 7.1 red motorola at startup
how to fix any root mistakes android
i need help fixing my root
need help repairing my droid x
root system mount fix droid
sbf wipe mount system
