Getting stuck at M logo during reboot
This is a discussion on Getting stuck at M logo during reboot within the Droid X Help forums, part of the Droid X Discussion category; Ever since putting boot strap and Froyo on my X every time I restart my phone freezes at the M logo. I have to do ...
Results 1 to 10 of 17
Like Tree2Likes
Thread: Getting stuck at M logo during reboot
    sublime118's Avatar
    860
    24
    Ever since putting boot strap and Froyo on my X every time I restart my phone freezes at the M logo. I have to do a battery pull every time I reset it. Anything easy I can try to stop this? Thanks!
    Brian
    Rescue Squad
    Points: 32,688, Level: 100
    DebianDog's Avatar
    6359
    "The Sticks", Virginia
    4,384
    332 times
    If you install Bootstrap then used ROM manager to upgrade you will need to bootstrap again. <top button> At least that fixed my same issue.
    DroidWhat's Avatar
    1497
    Ohio
    73
    Yes, Bootstrap is the reason for this (happened to me). I just removed the bootstrap for now (delete /system/bin/hijack, delete /system/bin/logwrapper, renamed /system/bin/logwrapper.bin to /system/bin/logwrapper)
    How one would do that if they have only the Moto Logo on their screen as I do and only get to the 'bootloader 30.01' sreen when doing a 'pwr/vol/cam' button sequence after a battery pull.
    Pensacola32526 likes this.
    Golfhunter28's Avatar
    272
    11
    Quote Originally Posted by hdokes View Post
    This is exactly what happened to me and where I'm at. I tried to flash with SBF but it failed. Please tell us how to remove the bootstrap with only these two screens. Thanks
    Points: 27,939, Level: 98
    Abe21599's Avatar
    Ohio
    4,864
    459 times
    when the M logo freezes, pull the battery and it should boot normally. dont hold any buttons.
    Points: 2,859, Level: 32
    Level completed: 73%, Points required for next Level: 41
    dipole's Avatar
    1500
    15
    Its there a more permanent fix than pulling the battery every time I reboot?
    DroidWhat's Avatar
    1497
    Ohio
    73
    The simplest fix is to open up the Droid X Bootstrap and click the Bootstrap Recovery button. I am not sure but you may have to click the Reboot Recovery button too and from recovery just reboot and all should be well.
    dipole's Avatar
    1500
    15
    Thanks, but when I do this, it seems like it boots up twice? First to the recovery screen, then I need to reboot again? Just making sure that this is the process.....
    Is there anyway to skip the recovery screen at this point or do I just have to live with it?
    Quote Originally Posted by DroidWhat View Post
    DroidWhat's Avatar
    1497
    Ohio
    73
    Yes, let it boot into recovery then select reboot and it should be fine after that (it should not boot into recovery again).
    If you look at my very first post in this thread i mentioned that i originally just removed the Bootstrap files and reverted back to the original logwrapper which this also fixed the issue too.
    I had lost root during my first update to Froyo so just went the easy route the second time (flash sbf, one click root, rom manager/bootstrap to install froyo). It seems the bootstrap gets kludged up causing this.
    **EDIT**... Need i mention that i re-installed bootstrap and it works fine. Its just that it appears after installing froyo the boot has this problem until you do this. At least for me it did.
  1. How do you manually reboot the Droid X?
    By Hephaestus in forum Droid X Help
    Last Post: 10-01-2011, 09:38 PM
  2. Resending SMS Text after Reboot
    By mnasholm in forum Droid X General Discussion
    Last Post: 07-06-2011, 12:51 AM
  3. X won't boot past M logo
    By fragar in forum Droid X Help
    Last Post: 11-17-2010, 08:53 PM
  4. Stuck at motorola logo...computer wont recognize phone
    By bill0405 in forum Droid X Help
    Last Post: 08-10-2010, 05:02 PM
  5. 7 days on the DX without a reboot.
    By tourrider in forum Droid X General Discussion
    Last Post: 07-23-2010, 01:25 AM
Motorola Cliq stuck on m logo
droid x frozen at the motorola logo
droid x frozen on motorola logo
droid x motorola logo stuck
droid x stuck at motorola logo
droid x stuck motorola logo
droid x stuck on moto logo
droid x stuck on motorola logo
stuck at motorola logo droid x
stuck on motorola logo droid x
