Droid x stock 4.5.605 bricked! I need help!
Ok, my DX is running stock 4.5.605 and i keeps rebooting 5-10 seconds after turning it on. When it reboots it skips the M logo. Same in safe mode and it resets the ringer volume everytime it turns on.
It doesnt stay on long enough for a factory reset and when I factory reset via recovery, it goes through but when I turn it on it still has all the user data. I've tried sbf .320,.340,.602 on rsdlite but it gets an error veryfing the code groups. I ve also tried the linux method and it goes all the way but nothing changes on my phone it still runs the same firmware with the same problem. Culd this be because of a USB cable. I am currently using the USB from my D2 and i am getting a DX USB cable on the 8th. Can someone help me?
02-04-2012 09:30 AM
Have you tried to get into stock recovery and doing a factory reset. Hold down home and power till you get the exclamation point. Then hit the volume up and down keys at the same time once. You should get a menu option to factory reset. Scroll down with volume keys and select with power button.
Which Rom am I running? All of them!!!!
yes i tried that. It seems to work but when i boot it nothing is different
Well since your completely stock why not try Verizon? I don't think a usb would be the issue since im using my old lg usb. I do know that when I was stock mine would reboot every time I would shut it off.
what do you mean by try verizon
Well if your phone is having issue why not try customer service?
ok ill try customer service. I just dont want to send my phone in for repairs because I dont want to pay 100 for a simple software replacement, aka i my warranty expried
ok both verizon and motorola are no help. Is there another way like the usb jig thing?
How about a battery pull? I am not familiar with the actual process...like when to pull it.
Pull the battery with the phone on. Wait 30 seconds then put it back in.
the battery pull didnt work. What is it suppose to say in device properties? When i go to it in windows seven it is under unspecified and the only device detail is the model: S Flash OMAP3630 MI
