Frankentext?
This is a discussion on Frankentext? within the Droid X Help forums, part of the Droid X Discussion category; Recently, my Droid X has been sending message that are mashed together. To elaborate, It will send part of the message, but it will be ...
Thread: Frankentext?
    Points: 281, Level: 5
    Level completed: 62%, Points required for next Level: 19
    Dex's Avatar
    48408
    Sep 2011
    Frankentext?
    Recently, my Droid X has been sending message that are mashed together. To elaborate, It will send part of the message, but it will be combined with a message that I had previously sent. This has just started happening in the past couple weeks, and it happens at random. I get poor reception at my house, so I thought that may have had something to do with it; however, it happened again today when I sent a text from the city, and I had a perfect signal. Most of the mash-ups involve unsent texts, but some of them have involved texts that had been delivered successfully. I wouldn't this mind this quite as much, but the worst part is some of the text I've send my girlfriend contain messages that were never delivered to her, so she had thought that I was texting another woman. It was a total headache. Has anyone experienced this glitch, and is there anything I can do to fix the problem? Thank you in advance.
    Points: 2,591, Level: 30
    Level completed: 94%, Points required for next Level: 9
    Overall activity: 13.4%
    Smittys's Avatar
    29353
    384
    8 times
    You don't happen to use handcent do you?
    Sent from my DX Vortex Dark Theme
    Spotlight Admin of the Month
    Points: 48,443, Level: 100
    Overall activity: 92.1%
    HarleyDude's Avatar
    19213
    Philly area
    7,038
    258 times
    Try going into settings > applications > manage applications > "all" tab > scroll to text messaging > click on it, then click "clear data" and "clear cache"
    Dex's Avatar
    48408
    Sep 2011
    No handcent for me; I've only used the stock text messaging app. I'm gonna try that trick, HarleyDude, and see if I have anymore problems with it. Thanks again.
