Damaged sd card! Please help me out guys/gals
This is a discussion on Damaged sd card! Please help me out guys/gals within the Droid X Help forums, part of the Droid X Discussion category; Hey guys i just was downloading a new rom on my computer and then when i plugged my phone in to the computer and put ...
Results 1 to 8 of 8
  • 1 Post By spodoc
Thread: Damaged sd card! Please help me out guys/gals
    Points: 1,853, Level: 25
    Level completed: 53%, Points required for next Level: 47
    Overall activity: 6.0%
    250 Experience Points100 Experience Points31 days registered7 days registeredTagger Second Class
    ac99's Avatar
    47350
    Sep 2011
    218
    Hey guys i just was downloading a new rom on my computer and then when i plugged my phone in to the computer and put on usb mass storage to transfer the rom to the phone (ive done this many times), but when i safely ejected the phone from the computer i got a damaged sd card warning saying i may have to reformat it! I have my photos saved but all of my roms, backups, apps data, etc. is on the sd card, and i really don't want to lose any of that, ive tried rebooting, didnt work, turning off taking out memory card putting back in then turning back on and it didn't, work. And my computer is not recognizing my phone now when i plug it in! Please help I'm going to need my sd card to be working for the weekend.
    ac99's Avatar
    47350
    Sep 2011
    218
    should i sbf? or will that not work without an sd card? i do have an extra, and also im on a rom (liberty 3) so if i reformat it what will happen since i installed liberty 3 and all my other roms to my sd card???
    Points: 5,942, Level: 49
    Level completed: 96%, Points required for next Level: 8
    Overall activity: 1.8%
    spodoc's Avatar
    17924
    2,043
    88 times
    It's late and I'm not reading your op closely, but in-general, if you have a failing memory, it's best to not use that memory until it's backed up. if you have pictures you want to save, don't use that card until you are ready to extract what you can. I'd go with software such as winhex. it allows you an incredible amount of power to find/extract files from damaged storage hardware.
    Good luck.
    superwrench likes this.
    ac99's Avatar
    47350
    Sep 2011
    218
    Quote Originally Posted by spodoc View Post
    Good luck.
    For now should i use a blank sd card and keep the damaged one asside to fix?
    spodoc's Avatar
    17924
    2,043
    88 times
    yeah, if you have a spare sd card to put in your phone, then I'd just go with that and keep your precious card off to the side till you can figure out which, if any, photos can be saved.
    Winhex is for some, incredibly difficult to use, but i've had tremendous success extracting valuable files from crashed hard drives. Good luck. Gotta run.
    ac99's Avatar
    47350
    Sep 2011
    218
    I have all of my photos saved it just my roms, apps, app data, etc. Also if i put a blank sd card in, what will happen to the rom im running?
    Points: 2,817, Level: 32
    Level completed: 45%, Points required for next Level: 83
    Overall activity: 3.7%
    jun991013's Avatar
    44807
    Jul 2011
    Santa Clara, CA
    403
    OK dude I had the same thing happen call customer service and say that when I formatted the SD card from the DX the SD card broke (which is true for me) and they sent em a new 16gb SD card with USB/Standard SD card adapters.
    Points: 972, Level: 16
    Level completed: 72%, Points required for next Level: 28
    superwrench's Avatar
    33695
    Michigan
    100
    It's late and I'm not reading your op closely, but in-general, if you have a failing memory, it's best to not use that memory until it's backed up. if you have pictures you want to save, don't use that card until you are ready to extract what you can. I'd go with software such as winhex. it allows you an incredible amount of power to find/extract files from damaged storage hardware.Good luck.
    Quote Originally Posted by ac99 View Post
    Your ROM should operate correctly with a new (blank) card because the ROM is OS (operating system) and should at this point be on the phone side of storage, not the sd card side.
    Any Android Phone at hand!!
  1. SD Card Damaged
    By Divey1130 in forum Droid X Help
    Last Post: 06-30-2011, 10:17 AM
  2. Hey Guys/Gals Rudybow here.
    By Rudybow in forum New Member Introductions & Site Assistance
    Last Post: 03-19-2011, 01:11 PM
  3. Help!! Damaged SD Card??
    By stevewitt in forum Droid X Help
    Last Post: 11-02-2010, 02:40 PM
  4. Damaged SD Card Notification
    By Evelgest in forum Droid X Help
    Last Post: 07-26-2010, 10:20 AM
android tablet damaged sd card
atrix sd damaged
blank sd card droid x
damaged sd card android
damaged sd card atrix
damaged sd card droid x
damaged sd card droid x fix
droid x damaged sd
droid x damages sd card
droid x not reading sd card
motorola atrix damaged sd card
phone reading damaged sd card
sd card from droid x damaged
sd card may be damaged on droid
your sd card may be damaged android
