What does Kernel Tweakig do?
This is a discussion on What does Kernel Tweakig do? within the Droid X Help forums, part of the Droid X Discussion category; found this feature on Android overclock my current Values are: Sampling Rate: 46875 Up Threshold (1-100%): 86 Powersave Bias (0-1000): 0 Ignore nice load [ ...
Results 1 to 2 of 2
Thread: What does Kernel Tweakig do?
    Points: 2,374, Level: 29
    Level completed: 50%, Points required for next Level: 76
    Overall activity: 5.8%
    naidanirt's Avatar
    38544
    359
    What does Kernel Tweaking do?
    Ignore nice load [ ]
    what do these do?
    and what would be some good values for these settings?
    Points: 11,986, Level: 71
    Level completed: 84%, Points required for next Level: 64
    Overall activity: 3.5%
    7 days registeredThree Friends100 Experience PointsYour first GroupCreated Album pictures
    Community Award
    AdamTomaino's Avatar
    434
    Pittsburgh, Pa
    614
    29 times
    Quote Originally Posted by naidanirt View Post
    what do these do?
    Sampling rate: How often your CPU "refreshes" to change its clock speed. Lower would theoretically yield better performance with more battery drain but I haven't seen much of a difference
    PowerBias: A scaling factor for the "Up Threshold" setting. High values will stretch the battery and yield lesser performance
    Up Threshold: the limit that the cpu load must reach before the speed clocks up or down. so lower = faster performance however more battery drain
    Ignore nice load [ ]: a bolian (yes/no) expression which decides if certain apps that draw very little cpu power should be skipped when CPU scaling takes place. "1" will stretch the battery further. I have had phantom resets using Ignore nice load [1] on my wife's fascinate.
    Important thing to remember is that the Kernal cannot be edited freely with a locked bootloader so Setcpu needs to be rerun everytime you start up your android devices (Dx)
    MORE CLEARLY at setcpu's website[http://www.setcpu.com/]:
    • Sampling Rate An interval (in microseconds) at which the governor will poll for updates. When this happens, the governor will decide whether to scale the CPU up or down.
    • Up Threshold – Defines a percentage from 1% to 100%. When the CPU load reaches this point, the governor will scale the CPU up.
    • Down Threshold (conservative only) – Defines a percentage from 1% to 100%. When the CPU load reaches this point, the governor will scale the CPU down.
    • Ignore Nice Load If this value is “1,” the system will ignore “Nice” processes when deciding to scale up or down.
    • Powersave Bias (ondemand only) Setting this value higher will “bias” the governor toward lower frequencies.
    Knight AdamTomaino of The X Clan!
  1. Using 1.4 ghz kernel on ssx 2.2
    By alpinestars96 in forum Droid X General Discussion
    Last Post: 11-09-2011, 09:27 AM
  2. CM7 on GB Kernel.
    By Chew DZ in forum Cyanogenmod
    Last Post: 11-04-2011, 07:39 PM
  3. Not sure if I am on. 340 kernel! Please help.
    By DroidX_46 in forum Droid X Hacks
    Last Post: 10-27-2011, 10:29 AM
  4. CM7 GB Kernel
    By Droidxuser5 in forum Cyanogenmod
    Last Post: 10-13-2011, 04:51 PM
  5. 2nd-init for GB kernel
    By brewcrewwheels in forum Gingerbread Roms
    Last Post: 09-03-2011, 01:42 AM
android power save bias
android powersave bias
android powersave bias setting
droid razr kernel sampling rates
droid x kernel tweaks
droid x sampling rate
ignore nice load
ondemand powersave bias
power save bias governor android
powersave bias
powersave bias (0-1000)
powersave bias android
what does changing the threshold do kernel
what does kernel tweaking do
what is powersave bias
