hey yall ive just started having trouble with my 3g going in and out to 1x. i tried to factory/restore, wipe cache. but nothing seems to work. i just sbf'd back to stock and still not working right. please help. thanks
This is a discussion on 3g signal in and out? within the Droid X Help forums, part of the Droid X Discussion category; hey yall ive just started having trouble with my 3g going in and out to 1x. i tried to factory/restore, wipe cache. but nothing seems ...
Try Dialing *228. Press option 2 at the prompt to update roaming.
Also what Bandbase version are you on ?( settings, about phone, band base version ie BP_C_01.09.13P [my current])
Knight AdamTomaino of The X Clan!
Running the same baseband but Im outside the Verizon coverage area to use the *228. Im currently in Alaska right now. So didn't know if there was another way around it.
yeah but i usually have data. if i try and fully activate i cant. but i will be out of this area before to long and wont have to worry about it anymore.
