My camera intermittently does not store photos taken. It comes back with an icon when I search for the photo just taken. It is very intermittent. It also does not playback the video taken.
This is a discussion on Camera Problems within the Droid X Help forums, part of the Droid X Discussion category; My camera intermittently does not store photos taken. It comes back with an icon when I search for the photo just taken. It is very ...
Sounds to me like a SD card issue.
Try removing everything from your card to a computer and format your card then replace the things you need/ want and see if that helps
Sent from my cm_tenderloin using Tapatalk
i thought this was supposed to be a bug fix on the .621
