I would like to use the Droid X as a WiFi enabled device (like a small tablet) but without
activating any data or minutes plan with Verizon. Can this be done, and if so, how?
Thanks.
This is a discussion on Can Droid X be used as WiFi device without activating the 3G phone? within the Droid X Help forums, part of the Droid X Discussion category; I would like to use the Droid X as a WiFi enabled device (like a small tablet) but without activating any data or minutes plan ...
Thanks.
Yeah, at the activation screen just tap the corners of the screen, starting at the top left and work around clockwise. It'll bypass the activation, and you have your wifi only device.
Think you're bricked? I beg to differ!
Droid X SBF
Droid X2 SBF
Rooting - Gingerbread and Froyo
Gingerbread Tethering Solutions
Thanks. New here (obviously) but sure like what I see.
Welcome to the forum and glad I could help you out! There's a lot of really good information and a lot of people who are more than willing to help you out should you need it.
Droid X SBF
Droid X2 SBF
This isnt working for me...
I was trying it after I clicked the android... and it needs to be done on the screen with the android ...
glad you got it working
Sent from my Droid X using Tapatalk 2
You guys are AWESOME........ Thank you so much for the help.
I play with my mother's old X that's not activated and use my X as a phone. My mother's X is my X-pod. Can't Swype on an iPod or iPhone
Every time I turn Xena on, she tells me that I need to activate her but I ignore her asking to be activated
