Need help putting back apps into the system/apps folder
This is a discussion on Need help putting back apps into the system/apps folder within the Droid X Help forums, part of the Droid X Discussion category; I rooted my droid x and removed blockbuster and amazon mp3 and I would like to get them back so when an update comes I ...
Results 1 to 10 of 10
Thread: Need help putting back apps into the system/apps folder
    anw36's Avatar
    6688
    28
    I rooted my droid x and removed blockbuster and amazon mp3 and I would like to get them back so when an update comes I will not get a bootloop. Is there any way to easily get them back in the system/apps folder that a 14 year old could do?
    Points: 25,696, Level: 96
    Level completed: 35%, Points required for next Level: 654
    Abe21599's Avatar
    Ohio
    4,864
    458 times
    http://www.chadhaney.com/droidXDefault/
    any apps you uninstalled you can find the .apks here. transfer to your sd card and move to /system/apps using root explorer (needs to be R/W)
    click to install, and then change the permissions: first column all checked, second column top one checked, third column none checked. change back to R/O and youre set
    anw36's Avatar
    6688
    28
    Is using root explorer the only way or are there any others?
    Abe21599's Avatar
    Ohio
    4,864
    458 times
    That's the easiest way IMO
    Sent from my phone... which happens to be a Droid X
    anw36's Avatar
    6688
    28
    I guess I will try it. Thanks but, would these apps really stop me from getting an update?
    anw36's Avatar
    6688
    28
    Will other file managers work such as estrongs or astro?
    anw36's Avatar
    6688
    28
    When i try to copy it to system/app i get a copy failed error any advice?
    anw36's Avatar
    6688
    28
    Ok. I think I got it to work but, how do i check to make sure?
    Abe21599's Avatar
    Ohio
    4,864
    458 times
    try to uninstall in settings. you cant uninstall system apps so that should tell u
    Points: 2,421, Level: 29
    Level completed: 81%, Points required for next Level: 29
    Lumberg's Avatar
    3651
    Philly
    83
    I was trying to put my system/app folder into 744 mode because I think this might have been the problem with the failing of the 2.2 during install. But I think I accidentally put it in 444 and now my phone is in a boot loop. Can someone please help me?!?!! How can I get this folder back to 744?
    Thanks!
  1. Replies: 24
    Last Post: 10-22-2010, 10:25 PM
  2. Moving market apps to system and theming
    By 92sho16 in forum Droid X Hacks
    Last Post: 07-25-2010, 08:32 PM
  3. Backup of system/apps folder?
    By zoulkyud in forum Droid X Hacks
    Last Post: 07-23-2010, 02:16 PM
  4. Moving unused apps to another folder? How?
    By thesnowgod in forum Droid X General Discussion
    Last Post: 07-21-2010, 03:29 PM
  5. droid apps vs app store apps
    By silent1643 in forum Droid X General Discussion
    Last Post: 07-18-2010, 03:39 PM
droid x installing sys apps
how to find system folder on droid x
how to ger permissions for system app folder
how to put apps back in the app folder on a droid
how to put apps back on droid x
how to put apps back on the app page on a droid tablet
put back the appps. removed while updating
putting deleted apps back in droidx
what is app folder on droid
where do apps get put in system folders
