Micro USB to HDMI won't work
This is a discussion on Micro USB to HDMI won't work within the Droid X Help forums, part of the Droid X Discussion category; 12/11 2:20 pm - Update to my original wording I got a 10' HDMI to HDMI cord (Droid to TV, computer, etc ) to connect ...
Thread: Micro USB to HDMI won't work
    Points: 4,660, Level: 43
    Level completed: 55%, Points required for next Level: 90
    Lane W's Avatar
    33056
    1 hour north of NYC
    325
    HDMI cord won't work
    I got a 10' HDMI to HDMI cord (Droid to TV, computer, etc) to connect my Dx to my TV (4 yr old 42" flatscreen Samsung), but it won't play. Connections ok, & I tried using the Xternal display app I downloaded the app 2-3 days ago). https://market.android.com/details?i...xternaldisplay
    Adjusted TV's input & executed the Xternal display app. No go, the TV displays "mode not supported." I can view pictures on the TV connecting the factory charge/data transfer cord, but am unable to play any Netflix movie, recording or video from my Dx to the TV with the cord I bought.
    Is there something in phone or app that's not set up correctly? Thanks in advance.
    Sent from my DROIDX using Droid X Forum
    DroidX GB 2.3.3 MB810 No Root
    Droid X2.....Eclipse .
    BIG THANKS to SD_Shadow who has also helped me dig out of a hole
    A BIG thank you to GoCliffGo who helped me get Eclipse on my X2
    When someone shares something of value with you, from which you
    benefit, you have a moral obligation to share it with others...
    Points: 1,445, Level: 21
    Level completed: 45%, Points required for next Level: 55
    SB50's Avatar
    40081
    25
    Does it work with the stock gallery app?
    Because it sounds like you got the wrong cable. you need a microHDMI to HDMI cable. MicroUSB to HDMI is only for phones that output HDMI through the microUSB port instead of having a dedicated microHDMI port.
    Lane W's Avatar
    33056
    1 hour north of NYC
    325
    My mistake for the wording. It is HDMI out (Droid) to HDMI in (TV). But the fact remains that the TV displays "mode not supported".
    I tried using the Xternal display app, but it doesn't work. Are there other alternatives for video out via HDMI on Dx to TV?
  1. Replies: 4
    Last Post: 05-29-2011, 12:10 PM
  2. Micro USB B male to micro USB B male cable
    By drzeus in forum Droid X Accessories
    Last Post: 05-03-2011, 11:01 AM
  3. How to sync work email and work wont let you
    By HUB SRT in forum Hacking Help
    Last Post: 01-06-2011, 05:44 AM
  4. Replies: 3
    Last Post: 11-04-2010, 01:18 AM
  5. Will they update the DX to work with a 64GB Micro SD?
    By bozidar0 in forum Droid X Accessories
    Last Post: 08-19-2010, 12:52 PM
android micro usb to hdmi out
droid razr usb to hdmi
droid to tv usb
micro hdmi not working razr
micro hdmi wont work
micro hdmi wont work s5
micro usb hdmi android
micro usb to hdmi not working
micro usb to hdmi wont work
use usb as hdmi droidx
