Authentication error?
This is a discussion on Authentication error? within the Droid X Help forums, part of the Droid X Discussion category; Have had my Dx since April 2011 & am quite satisfied with it (stock MB810 with GB 2.3.3). I've been receiving this for a few ...
Results 1 to 9 of 9
Thread: Authentication error?
    Points: 4,660, Level: 43
    Level completed: 55%, Points required for next Level: 90
    Lane W's Avatar
    33056
    1 hour north of NYC
    325
    Have had my Dx since April 2011 & am quite satisfied with it (stock MB810 with GB 2.3.3). I've been receiving this for a few days.
    Gmail: Authentication error receiving
    Anyone know why this is happening and have any thoughts on how to make it stop?
    Thanks in advance
    Happy Thanksgiving!
    Droid X2.....Eclipse .
    BIG THANKS to SD_Shadow who has also helped me dig out of a hole
    A BIG thank you to GoCliffGo who helped me get Eclipse on my X2
    When someone shares something of value with you, from which you
    benefit, you have a moral obligation to share it with others...
    Points: 67,578, Level: 100
    Overall activity: 16.2%
    HarleyDude's Avatar
    19213
    Philly area
    8,191
    460 times
    Verify you can still access your account with a PC, so you know it was not hijacked. Then wipe and re-setup your gmail account
    settings > applications > manage applications > "all" tab > scroll to gmail > click on it, then click "clear data"
    Lane W's Avatar
    33056
    1 hour north of NYC
    325
    No problem accessing gmail from my PC. What will this clear? Just the crap on the Droid? Or will I lose emails that are in my gmail?
    I thought about removing gmail & reinstalling it (I've removed aol a few times due to this same issue) but was concerned that no gmail would affect the operation of my DX.
    Thanks for your reply.
    Lane W's Avatar
    33056
    1 hour north of NYC
    325
    Harley I followed the steps to wipe data (only like 360KB) but, not sure I follow you on "re-setup your account". Does this mean go to gmail on my Dx and "Remove account" and then "Add account"? From here all the Settings & incoming/outgoing server info will automatically load/install? It all makes sense but I want to confirm I'm doing this right before doing making a mistake. Thanks again for your help & advice.
    Lane W's Avatar
    33056
    1 hour north of NYC
    325
    Quote Originally Posted by HarleyDude View Post
    Sorry, yes
    Ok, I did this late this morning and let the phone sit while I was watching football games. It began to install, but I got this: Error adding account. Automatic set up is not available for you email provider. Please manually set up email account. (I don't understand how/why gmail does not set up automatically?)
    Now I see I received this: Connection error - The following error has prevented a successful connection: Unable to connect to smtp.gmail.com. So I removed gmail to add the account again.
    Email "Gmail"
    General Settings
    - Account name - Gmail
    - Real name - my gmail address is already in this section
    - Email address - Again, my gmail address is already in this section
    Incoming Server
    POP mail server
    Server
    gmail.com
    Username
    my gmail address is already in this sectiom
    Password
    xxxxxxxxxxxx (my password is here in x's)
    Advanced settings
    Incoming server: Advanced settings
    Port 110
    Use secure connection box not checked
    Use secure password (TLS):
    Auto
    Authentication
    Password
    Verify certificate box is checked
    Outgoing server
    Advanced settings
    Port 25
    Use secure connection box is not checked
    Auto
    Authentication: Auto
    IMAP mail server
    Server
    gmail.com
    Username
    my gmail address
    password
    xxxxxxxx
    Auto
    I read through all 4 pages at this link (10/25/11) but cannot determine the correct settings. I seem to remember one of the ports being 993 or 995, but I made the dumb decision to remove gmail this morning without making notes of the existing ports.
    http://www.droidxforums.com/forum/droid-x-help/39189-email.html
    Please advise what my next/best course of action is. Thank you
    HarleyDude's Avatar
    19213
    Philly area
    8,191
    460 times
    I have not set up gmail as a pop account, I use the other two methods.
    I'd suggest the native gmail app, click on gmail in the app drawer and not email, and set up your account that way. If you want to use the email client, set it up as IMAP, not as POP
    Log into gmail on your PC, go to settings and click IMAP setup at the top. You need to enable it here first (I believe you also need to do this for POP)
    Directions are right there, but basically on the phone, create a new email account and put your google user and password. Use security for the advanced options, auto, I believe. And you don't need certificate checked
    Lane W's Avatar
    33056
    1 hour north of NYC
    325
    I had similar issues when I first got my Dx April 2011. Today I ended up removing & adding gmail 3-4 times & the last attempt loaded successfully. Tested sending AOL email to Dx and from DX to AOL & everything's good to go
    Thanks for your advice Harley
    For anyone else searching for this set up, this is what I used 11/27/11
    Incoming server, port 993
    imap.gmail.com
    Outgoing server, port 465
    smtp.gmail.com
  1. Replies: 0
    Last Post: 07-02-2011, 05:16 PM
  2. Yahoo: Authentication Error
    By Ann in forum Droid X Help
    Last Post: 05-31-2011, 02:09 PM
  3. error with hotmail "authentication error receiving"
    By hunterchick in forum Droid X Rescue Squad
    Last Post: 04-09-2011, 01:45 AM
  4. Authentication Error
    By Tyler in forum Droid X General Discussion
    Last Post: 02-14-2011, 08:37 AM
  5. Gmail authentication error
    By TwitTwit in forum Droid X Help
    Last Post: 02-13-2011, 03:27 PM
authentication error droid
connection error the following error has prevented a successful connection
droid x authentication error
gmail authentication error android
hotmail authentication error android
the following error has prevented a successful connection incorrect username or password
the following error has prevented a successful connection invalid server certificate
yahoo authentication error
yahoo authentication error android
