Separating email/text alerts
This is a discussion on Separating email/text alerts within the Droid X Help forums, part of the Droid X Discussion category; I see how to set alert sounds and ringtones, but is there a way to separate email alert from text alert? The original Droid allowed ...
Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By LordButt
  • 1 Post By smalltowngirl13
Thread: Separating email/text alerts
    Montu's Avatar
    4512
    40
    I see how to set alert sounds and ringtones, but is there a way to separate email alert from text alert? The original Droid allowed for this.
    Points: 2,244, Level: 28
    Level completed: 63%, Points required for next Level: 56
    LordButt's Avatar
    3229
    Midland, TX
    87
    Yes
    Go to email, email settings, notifications, select ringtone.
    You can get a copy of the manual here:
    DROID X - User's Guide & GSG
    Montu likes this.
    Motorola Droid X
    Simply Stunning 2.1
    Android Version 2.3.5
    Kernel Version 2.6.32.9-g55626e1
    Base-band BP_C_01.09.07P
    Points: 77,892, Level: 100
    Overall activity: 71.7%
    20,509
    885 times
    In addition to the above, there is an app called GMail Notifier that allows you customize incoming gmail alerts (if you are using the stock gmail app)...
    Montu likes this.
    Montu's Avatar
    4512
    40
    I'm about to check it out now. Thanks.
    Points: 12,406, Level: 72
    Level completed: 89%, Points required for next Level: 44
    Your first Group250 Experience PointsCreated Album pictures100 Experience Points7 days registered
    chucklehead's Avatar
    1224
    Pgh, PA
    1,396
    54 times
    Be sure to double check whichever apps your using for other things also. If you use Handcent for sms but other apps for gmail and email, make sure you have them all set up accordingly. Might have to turn notifications off in one of the others. You could end up getting all sorts of different notifications for different things and it can get quite confusing.
    I'm having a similar problem. I have four accounts, one gmail and two corporate and an AT&T account all set up. I can set the Gmail account to a different ringtone and it stays the way I set it and all is right in google world, but if I change say, my at&t ringtone ten it changes the corporate email accounts' ringtones as well. Any thoughts?
  1. stupid question (vibrating text alerts)...
    By KDogg in forum Droid X Help
    Last Post: 02-05-2015, 10:42 PM
  2. Customizing individual email account alerts
    By QuadsWest in forum Droid X Help
    Last Post: 09-02-2010, 12:37 AM
  3. calendar alerts never happening...
    By cloutier in forum Droid X Help
    Last Post: 08-15-2010, 07:57 PM
  4. Replies: 2
    Last Post: 08-04-2010, 05:05 PM
  5. Alerts
    By elauer in forum Droid X Help
    Last Post: 07-30-2010, 01:20 PM
Droid x text alerts
can i seperate sms alert from gmail alert on droid
can i set a separate alert for texts and other notifications on my droid razr m phone?
droid how to set text alert
droid x alert
droid x email alert
how do i delete email alerts from droid
how to display emails separately on droidx
how to manage email and text alerts separately on android
separate email notifications droid x
