GPS not working, need opinions/dianostic ideas
This is a discussion on GPS not working, need opinions/dianostic ideas within the Droid X Help forums, part of the Droid X Discussion category; I received a replacement (refurbished) X last week, and on Saturday I planned on using Navigation to find this one place. GPS locked on fine, ...
Results 1 to 10 of 10
Thread: GPS not working, need opinions/dianostic ideas
    Points: 926, Level: 16
    Level completed: 26%, Points required for next Level: 74
    Stuckinabox's Avatar
    42491
    Jul 2011
    96
    GPS not working, need opinions/diagnostic ideas
    I received a replacement (refurbished) X last week, and on Saturday I planned on using Navigation to find this one place. GPS locked on fine, but about ten minutes into the trip it lost it and didn't pick it back up. I believe at that point I had already flashed CM7.
    I figured it was a temporary thing, but it hasn't been able to find any satellites since then. The indicator just flashes endlessly.
    -Was on CM4DX-GB, GPS stopped working, tried rebooting, battery pull, flashing a fix, turning the different services on and off.
    -SBF'd to Froyo .340, no luck, tried the same stuff.
    -OTA'd to .605, ditto. Even left it in navigation searching for GPS overnight.
    Looks pretty broke' to me. Any other suggestions before I request another replacement? :|
    I had a similar problem. I found that if I took the battery cover off it now works. Even just unlatching the cover without taking it off entirely allowed it to work. I found this trick onthe a Verizon forum. I called Verizon and they replaced the phone.
    Points: 1,296, Level: 19
    Level completed: 96%, Points required for next Level: 4
    realtormicah's Avatar
    27647
    54
    Quote Originally Posted by Stuckinabox View Post
    Go to settings, location and security, make sure the box for use wireless networks is unchecked. I found that if this is checked I always have issues. If that doesn't work I am out of suggestions.
    Sent from my DroidX running (insert new Rom) using Droid X Forums
    42491
    Jul 2011
    96
    Quote Originally Posted by mcjohnson74 View Post
    Yeah, I heard that, no dice.
    Quote Originally Posted by realtormicah View Post
    That option doesn't seem to be available in .605.
    Points: 792, Level: 14
    Level completed: 92%, Points required for next Level: 8
    Overall activity: 1.0%
    cpurick's Avatar
    21668
    25
    What do you want to bet your "refurbished" DX was returned by a user who couldn't get GPS to work continuously?
    As far as I'm concerned, your responsibility for solving this was met as soon as you flashed the factory ROM onto the phone. After that it's a Motorizon issue. Call them about sending it back.
    42491
    Jul 2011
    96
    I did the exact same thing when the ear speaker stopped working on my original phone. If I SBF and factory reset and it's still not working, it sure as hell isn't my fault.
    42491
    Jul 2011
    96
    Okay, this is weird. I finally call verizon, he asks me to switch ALL location services on and it starts working...um.
    So I flashed CM7 thinking it was working, but suddenly it craps out again. I get one or two satellites, then about an hour later there's SEVEN suddenly. It's in and out...could that be hardware?
    cpurick's Avatar
    21668
    25
    How long did you run it on Motorizon before switching to CM7? If you're sure it's not intermittent on the Motorola software, then the problem's likely CM7.
    42491
    Jul 2011
    96
    I ran on stock software for almost two weeks, and I had tried the various locations setting combinations. The first time it worked was when I was on the phone with the guy. I flashed CM7 and it didn't work, then it worked very well a few times over the course of a few days. Right now it's back to not picking up any satellites.
    42491
    Jul 2011
    96
    Okay, for awhile I thought I was just erroneously trying to use it indoors, but there's clearly something wrong with the phone. I can go outside and hold it and have it not pick up anything usually, but when I hold the phone a certain way or squeeze the case near the volume button, it starts to pick up. With the old phone I could switch gps on, set it on my dash and go.
  1. Working on Icon set (opinions please)
    By psykotikz in forum Droid X Themes
    Last Post: 08-10-2011, 02:21 PM
  2. Any Ideas?
    By frosty_35768 in forum Droid X Help
    Last Post: 08-04-2011, 08:10 PM
  3. Wireless Tether not working? Any ideas?
    By glibbster in forum Gingerbread Development and Hacking
    Last Post: 05-13-2011, 01:06 AM
  4. Any ideas?
    By kjguy43 in forum Droid X Rescue Squad
    Last Post: 02-06-2011, 04:26 PM
  5. WiFi File Explorer not working ... looking for ideas
    By dtsig in forum Droid X General Discussion
    Last Post: 01-20-2011, 01:49 PM
Navigation on droid x not working
droid x gps not working
droid x navigation not working
droid x2 gps doesn't work
droid x2 gps not working
droid x2 searching for gps
gps not working on droid x
gps not working on droid x2
gps on droid x not working
navigation not working on droid x
