My droid X came unrooted after most recent update - HELP!
This is a discussion on My droid X came unrooted after most recent update - HELP! within the Droid X Help forums, part of the Droid X Discussion category; After I took the most recent update that my phone has recieved - my phone's app's that rely on rooting are not working. (the version ...
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: My droid X came unrooted after most recent update - HELP!
    Points: 46, Level: 1
    Level completed: 92%, Points required for next Level: 4
    7 days registeredTagger Second Class
    alyssagrahamm's Avatar
    49611
    Oct 2011
    Unhappy My droid X came unrooted after most recent update - HELP!
    After I took the most recent update that my phone has recieved - my phone's app's that rely on rooting are not working. (the version it says im running on is 2.3.3 in my about phone section). I tried using wireless tethering and it says- unable to star tethering. is your device rooted?
    I have z4root on my phone.
    When I open the app - It gives me to options - Temp Root, Permanent Root, or Un-Root
    I figure since unroot is an option , that my device should be rooted.
    When I click on any of these - it sits there spinning forever, and either takes an hours with nothing
    or the app closes and nothing is fixed...
    Can someone pleaseeee help me?
    Im not a super genius with my droid - but I feel like it isnt working like it suppose to.
    Rescue Squad
    Points: 23,600, Level: 94
    Level completed: 25%, Points required for next Level: 750
    Overall activity: 17.7%
    Leach19m's Avatar
    31277
    Washington
    6,175
    195 times
    Z4 doesn't work on gingerbread, check out the gingerbread root link below to root your phone
    [ROOT][HOW TO] Win/Linux/OS X [Latest DX .602/.605]
    (V) {;,,;} (V) < Woopwoopwoopwoopwoop
    Scuttering along like Zoidberg, on the move
    Points: 1,326, Level: 20
    Level completed: 26%, Points required for next Level: 74
    Overall activity: 0.7%
    prpredators's Avatar
    16471
    48
    I'm on froyo z4 rooted. If I take the update that keeps popping up, it will unroot me then I can use the last option for the one click root on my phone? I have a mac do prefer a one click root on my phone like z4.
    The z4 root for froyo was so simple. Afraid to update to gingerbread and not get root back
    Quote Originally Posted by Leach19m View Post
    Rescue Squad
    Leach19m's Avatar
    31277
    Washington
    6,175
    195 times
    Yup, you will lose root, but you can use this one click method to regain. Unfortunately there is no on-phone method like z4root for gingerbread, but this will work for a mac, just follow the appropriate instructions in the thread linked
    16471
    48
    ill have to take a look at it
    Thx
    49611
    Oct 2011
    Thank you for the link..
    Do you know of a way to uninstall the update.. there
    are several extra instructions for the droid x's that were previously rooted..
    I;d rather go back to my other version where my z4root works
    Rescue Squad
    Leach19m's Avatar
    31277
    Washington
    6,175
    195 times
    If you've already updated, the only way to downgrade is to SBF to it (wipes your phone and installs s fresh, stock, official build of whichever versions sbf you choose).
    Points: 4,496, Level: 42
    Level completed: 73%, Points required for next Level: 54
    Overall activity: 31.9%
    DroidXSkywalker's Avatar
    33436
    In the world of Does. I was raised by Droids
    956
    9 times
    Actually I rooted my X with one click while on Gingy. I used an app I downloaded to my cpu, called Motorola One Click Root Tool. I'll post the link on here so you can download it to your cpu, not your X. All you do is download the app to your pc then download MotoHelper, which Motohelper updates your drivers for you. You have to download it, cuz if you don't have the correct drivers it won't work. Motohelper is free on Motorola's site, which it checks to ensure the correct drivers are on your cpu, and don't delete it off your cpu (learned that the hard way), cuz your X won't work properly when you try to do stuff with it on your cpu. I'll post that link as well. Then after the drivers are installed, make sure your the Moto one click is running on your cpu, then when it tells you to, plug your X in, and follow the on screen directions, and them you'll be rooted. You will have an app called Superuser on it. You have to have it in order to do stuff with your X that requires root. I'm going to post the links in a separate post after this one. Hope this helps. It's the only one I've found to work with Gingy. It works with all Moto phones from the DROID series, including the Bionic. It has a list of supported devices, but some DROID phones from Moto are not listed including the Bionic, but they have been known to work.
    Droidlynn & X
    Rescue Squad
    Leach19m's Avatar
    31277
    Washington
    6,175
    195 times
    That's in the link I posted
    33436
    956
    9 times
    This is the root app I used:
    http://www.psouza4.com/Bionic/
    This is Moto helper:
    http://www.motorola.com/staticfiles/...iver_5.0.0.exe
    Droidlynn & X
  1. GPS stopped working after most recent update
    By chilehead in forum Droid X General Discussion
    Last Post: 08-20-2011, 03:07 PM
  2. Recent GB update now no WIFI
    By slolx50 in forum Gingerbread Help
    Last Post: 06-23-2011, 09:29 PM
  3. Droid x Unrooted Gingerbread Update Question????
    By thearchiexdm32 in forum Gingerbread General Discussion
    Last Post: 06-02-2011, 08:18 PM
  4. Replies: 42
    Last Post: 03-01-2011, 10:27 AM
  5. Please help with the most recent update
    By feds6745 in forum Droid X Stock Issues
    Last Post: 12-11-2010, 09:06 AM
Droid x unrooted after update
android update unrooted my phone
can z4 safely unroot my droid x
droid x unroot
droid x unrooted after last update
droix x unroot
phone unrooted after update
root droid x after gingerbread update
root my droid x
update droid x no longer showing root
update unrooted my droid
update unrooted my droid x
verizon update unrooted my phone
z4 doesnt work after update
