My droid X came unrooted after most recent update - HELP!
This is a discussion on My droid X came unrooted after most recent update - HELP! within the Droid X Help forums, part of the Droid X Discussion category; Before you root, make sure you have USB Debugging enabled. To do this, go to Settings-Applications-Development, and check USB Debugging. The check box next to ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: My droid X came unrooted after most recent update - HELP!
    Points: 4,496, Level: 42
    Level completed: 73%, Points required for next Level: 54
    Overall activity: 31.9%
    DroidXSkywalker's Avatar
    33436
    In the world of Does. I was raised by Droids
    956
    9 times
    Before you root, make sure you have USB Debugging enabled. To do this, go to Settings-Applications-Development, and check USB Debugging. The check box next to USB Debugging must be green
    Droidlynn & X
    Points: 46, Level: 1
    Level completed: 92%, Points required for next Level: 4
    7 days registeredTagger Second Class
    alyssagrahamm's Avatar
    49611
    Oct 2011
    I didnt have my drivers installed correctly! Once I got those in ~ the first link worked perfectly! Thanks everyone!
  1. GPS stopped working after most recent update
    By chilehead in forum Droid X General Discussion
    Last Post: 08-20-2011, 03:07 PM
  2. Recent GB update now no WIFI
    By slolx50 in forum Gingerbread Help
    Last Post: 06-23-2011, 09:29 PM
  3. Droid x Unrooted Gingerbread Update Question????
    By thearchiexdm32 in forum Gingerbread General Discussion
    Last Post: 06-02-2011, 08:18 PM
  4. Replies: 42
    Last Post: 03-01-2011, 10:27 AM
  5. Please help with the most recent update
    By feds6745 in forum Droid X Stock Issues
    Last Post: 12-11-2010, 09:06 AM
Droid x unrooted after update
android update unrooted my phone
can z4 safely unroot my droid x
droid x unroot
droid x unrooted after last update
droix x unroot
phone unrooted after update
root droid x after gingerbread update
root my droid x
update droid x no longer showing root
update unrooted my droid
update unrooted my droid x
verizon update unrooted my phone
z4 doesnt work after update
