Screen Issue (Line across top, slight flicker)
This is a discussion on Screen Issue (Line across top, slight flicker) within the Droid X Help forums, part of the Droid X Discussion category; I just swapped out an X i had due to constant rebooting, and just before the swap it began to flicker the whole screen badly. ...
Results 1 to 2 of 2
Thread: Screen Issue (Line across top, slight flicker)
    Points: 677, Level: 13
    Level completed: 54%, Points required for next Level: 23
    Overall activity: 1.7%
    yambag021's Avatar
    29971
    35
    I just received my re-furb yesterday. Fired it up, massive improvement from the one that wasnt working. HOWEVER, i notice now that at the top left when "using" it (either swiping between screens or when loading apps aka when the phone is "working"), i notice a slight flicker in the top left corner or a line that goes across the screen.
    The flicker is mostly when it is loading something (almost like the hourglass when loading a program on a cpu), the "line" when i am using the screen (when swiping between home screens).
    Any help? I'm thinking this MAY be a battery issue since i did not swap that out.
    I am running stock stuff, all updates have been done.
    HELP PLEASE
    Points: 45,910, Level: 100
    DirtyDroid's Avatar
    28665
    Upstate,NY
    14,576
    384 times
    seems more like another hardware/pixel problem? did you call vzw and tell them about it?
  1. Partial screen flicker/static.
    By ejgilkey in forum Droid X General Discussion
    Last Post: 09-05-2011, 12:13 PM
  2. ROM- Stripped down .596 with some slight mods
    By Megalosdog in forum Droid X Hacks
    Last Post: 07-14-2011, 07:25 PM
  3. Severe Screen Flicker
    By FA1SGL in forum Droid X Help
    Last Post: 02-08-2011, 04:23 AM
  4. Is the.little light suppose to flicker?
    By Mudig in forum Droid X General Discussion
    Last Post: 09-08-2010, 10:17 PM
  5. Music app in-line button control issue
    By pERUVIANeDDIE in forum Droid X Apps
    Last Post: 08-22-2010, 12:52 AM
droid bionic screen flicker
droid bionic screen flickering
droid bionic screen flickers
droid x flickering screen
droid x line across screen
droid x lines across screen
droid x screen flicker
droid x screen lines
galaxy s2 line across screen
line across droid x screen
