Black Spot on Screen
This is a discussion on Black Spot on Screen within the Droid X Help forums, part of the Droid X Discussion category; A couple of months ago I noticed a fine horizontal line on my screen. Then there were several more, all parallel, in the same 1/4" ...
Results 1 to 10 of 16
Thread: Black Spot on Screen
    Points: 236, Level: 4
    Level completed: 72%, Points required for next Level: 14
    100 Experience Points31 days registered7 days registeredTagger Second Class
    VAlcenius's Avatar
    47556
    Sep 2011
    Colorado Springs, CO
    Then there were several more, all parallel, in the same 1/4" area that approximated a circle.
    Now they have filled in so there is a black circle 1/4" diameter, centered 7/16" from the left of the screen edge and 15/16" up from the bottom. (For those using the screen lock app, it's almost directly over the bottom left dot)
    I have a screen protector that would show any trama to the screen and nothing appears to have struck it. (Bet I have a hard time convincing the store of THAT.)
    I also have the spot that ripples when pressing the screen that has been mentioned elsewhere, but this is separate and a little to the left of that one.
    Any history of THIS kind of thing out there. I'd like to show that I'm not the only one. Any suggestions? I can attach pic if needed.
    Jay
    Points: 1,537, Level: 22
    Level completed: 37%, Points required for next Level: 63
    ajs8403's Avatar
    43016
    Jul 2011
    Ohio
    94
    you got me man, my screen is fine, sorry about your luck...
    Ready.... Set.... GO!
    Points: 51,689, Level: 100
    Overall activity: 99.9%
    fezrock's Avatar
    29044
    Asheville-ish
    10,465
    573 times
    If your phone is under a year old, get it replaced. All I got, sorry.
    Points: 1,348, Level: 20
    Level completed: 48%, Points required for next Level: 52
    Pacidermiz's Avatar
    24104
    11
    I had this happen twice, once three days after release day, and fixed it with a factory re-set. Then about two months ago, running Liberty v0.4. A reload of the ROM did not fix it at first, I had to.sbf it back to a verizion ROM, after wiping/formating all the data partitions (except my SD card thankfully). Then the line dissapeared. Never had it grow into a digital tumor like yours tho- just a single line, horizontal across the screen, about 2/3rds of the way up. But both times it was in the same spot (as close as I could tell).
    But I'de replace it under waranty, like the other guy said, I am now dealing with the lower 1/4 of my screen being black with white verticle lines that no amount of mucking with the software/hardware is fixing. So good luck, whatever you do.
    P.S.- mine is over a year old, and VZ is still waranty replaceing mine. I told them how it happened: while watching a 4X3 aspect show on netflix, the area on the right (landscape) started with the white lines, then when I closed netflix, the area stayed black. Then I mentioned that it was the first time I'de opened netflix since their OTA update to 4.5.602.
    Last edited by Pacidermiz; 09-07-2011 at 08:11 PM. Reason: added post script to give additional advice
    Points: 101, Level: 2
    Level completed: 2%, Points required for next Level: 49
    mygeek911's Avatar
    47641
    Sep 2011
    I had to register just to post my own frustration with the same issue. I, however, have three large spots and two more forming on my screen. When I called Verizon about three weeks they accused me of dropping my phone and told me this wasn't a "known issue".
    To be honest, I watched Netflix the night before, placed the phone face down on a desk, and the following morning woke up to several horizontal lines that took up about 1/4 of the screen. The lines morphed and finally settled into the three large dots between 3/8" to 1/4" in diameter each. The other two forming dots appear they will be smaller.
    What is weird is that the dots have a yellow 'halo' around them when the background of the screen is white, but when it is blue the halo turns white. I want my phone replaced, but Verizon tells me to either stick with the phone or purchase a new one. This one isn't even two years old.
    Points: 3,238, Level: 35
    Level completed: 26%, Points required for next Level: 112
    JDW's Avatar
    23329
    Cleveland, Ohio
    67
    Quote Originally Posted by mygeek911 View Post
    Ever have any luck with VZW replacing it? Same issue here. And I didn't drop it and don't recall anything that could have caused it.
    Points: 1,265, Level: 19
    Level completed: 65%, Points required for next Level: 35
    GunJam's Avatar
    47086
    Aug 2011
    104
    Hummm
    I dont yet know much about these phones but I want to say its a hardware issue? Do you guys notice the issue on startup? or only once it fully boots up?
    Any sufficiently advanced technology is indistinguishable from magic.
    -Arthur C. Clarke.
    mygeek911's Avatar
    47641
    Sep 2011
    @JDW
    I was hoping to take the phone to a Verizon store while we were out of town, because anybody looking at the phone would realize it isn't a 'dropped-phone' issue. I haven't tried calling back with Verizon. Long story to your question is no.
    @GunJam
    It is definitely hardware related. You cannot see the spots when the phone is off, but as soon as you turn it (even before it boots) you can see them from the backlight.
    GunJam's Avatar
    47086
    Aug 2011
    104
    sounds like it could possibly be fixed with a new screen. They run about 40 bucks. If you can deal with the small parts and not get dust and finger prints all over the screen or break the connector clamps or sockets its a really easy fix.
    -Arthur C. Clarke.
    johniii's Avatar
    36699
    southeast michigan
    39
    i have a vertical line looks like a scratch i have to peel the protective cover back to check it.should i take it to a Verizon store? i dont know if its covered or not phone is maybe 6 months old.and how do i save all my apps and stuff on this stock phone?
  1. Anyone have a soft spot on their screen???
    Last Post: 07-12-2012, 02:45 PM
  2. black hat 3g hot spot
    By beachy in forum Droid X Hacks
    Last Post: 01-16-2011, 07:42 PM
  3. black hat 3g hot spot
    By beachy in forum Droid X General Discussion
    Last Post: 01-16-2011, 08:11 AM
  4. Will VZW replace my phone if there is a massive soft spot on my screen?
    By hijackerjack in forum Droid X General Discussion
    Last Post: 12-02-2010, 08:19 PM
  5. Weak spot in screen
    By jab1472 in forum Droid X Help
    Last Post: 11-22-2010, 11:06 PM
black dots on droid x screen
black dots on motorola droid x screen
black dots on screen droid x
black spot on droid screen
black spots on droid x screen
droid x black spots
droid x has black spots on screen
how to fix black dots on droid x
how to fix black spots on droid screen
motorola droid x black spots on screen
