Anybody have any tips or suggestions for cleaning these? My back button has a stickiness to it, which keeps it from really working properly.
This is a discussion on Hard Keys within the Droid X Help forums, part of the Droid X Discussion category; Anybody have any tips or suggestions for cleaning these? My back button has a stickiness to it, which keeps it from really working properly....
If your rooted you can use button savior app then you won't have to use your hard key buttons. As far as cleaning them im not sure
as far as a suggestion... take the battery out... use something like rubbing alcohol... and pop the cap off underneath the buttons there... use a q tip and carefully dab it....
that's what i would do anyways
Post Script:
Nemo Aeternamn Wallpapers
