Can't power-on droid
This is a discussion on Can't power-on droid within the Droid X Help forums, part of the Droid X Discussion category; My droid froze so I removed the battery to reset it. I reinstalled the battery and now can't power-on at all. When I connect to ...
Thread: Can't power-on droid
    Points: 124, Level: 2
    Level completed: 48%, Points required for next Level: 26
    bekmonster's Avatar
    46940
    Aug 2011
    My droid froze so I removed the battery to reset it. I reinstalled the battery and now can't power-on at all. When I connect to cradle, I see Motorola splashscreen, then an icon showing the battery with a question mark. Clearly, the droid doesn't recognize the battery now. I've reinstalled the battery a dozen times, so difference. Help!
    Points: 49,198, Level: 100
    Overall activity: 3.0%
    macpro88's Avatar
    20491
    6,938
    320 times
    If the phone is stock, take it in. Sounds like a battery issue or some thing wrong with the way the phone recognizes it. Hardware issue probably.
    [Insert mobile sig here]
    Points: 22,113, Level: 92
    Level completed: 77%, Points required for next Level: 237
    BHuber09's Avatar
    34670
    Atlantis
    6,636
    446 times
    Plug it in without the battery until you get the ? logo then put the battery in see if that makes a difference.
    FreeMyMoto!!!
    FreeMyMoto!!!
    If you need help PM me!!!
  1. Replies: 6
    Last Post: 11-16-2011, 07:23 AM
  2. Droid X Turns ON After I Power It OFF
    By artmanphoto in forum Droid X Help
    Last Post: 08-17-2011, 10:41 AM
  3. My Droid X will not power on unless 15% battery
    By borostang in forum Droid X General Discussion
    Last Post: 03-03-2011, 02:07 PM
  4. Alarm is not working when droid x is power off
    By MDDC in forum Droid X General Discussion
    Last Post: 10-01-2010, 07:00 PM
  5. Another power source for the Droid X?
    By djthomas in forum Droid X General Discussion
    Last Post: 09-08-2010, 12:57 PM
can't power on droid
can't see time or battery on my droid x
cannot turn on droid x battery
droid 3 battery question mark
droid 3 battery with question mark
droid 3 can't power on
droid 3 question mark battery
droid x battery question mark
droid x battery with question mark
motorola droid 3 battery question mark
