3G Still Not Working After Hard Reset
This is a discussion on 3G Still Not Working After Hard Reset within the Droid X Help forums, part of the Droid X Discussion category; For some reason my Droid's 3G is not working. I've searched this forum and also searched google. I've checked the battery settings and I've done ...
Results 1 to 9 of 9
Thread: 3G Still Not Working After Hard Reset
    Points: 166, Level: 3
    Level completed: 32%, Points required for next Level: 34
    Concoursrider's Avatar
    45742
    Aug 2011
    Angry 3G Still Not Working After Hard Reset
    For some reason my Droid's 3G is not working. I've searched this forum and also searched google. I've checked the battery settings and I've done the data manager troubleshoot as well. I just did a factory reset and it's still not working. I don't know what else to do and really to do. I appreciate the help.
    Points: 1,105, Level: 18
    Overall activity: 2.5%
    Zog's Avatar
    38332
    320
    7 times
    Is there a 3g icon (w/ full bars) and no data transfer? Does it stay on 1x instead, or do you get no internet at all?
    Is your background data turned on? Perhaps you bumped a toggle for it, easily done on a rom like miui.
    Are you on stock gingerbread?
    You don't see a triangle on your notification bar do you?
    - sent from my liberated dx
    45742
    Aug 2011
    I'm sorry, but I don't know what gingerbread is. I am not getting the 3G icon at all and my background data is checked.
    Points: 154, Level: 3
    Level completed: 8%, Points required for next Level: 46
    Overall activity: 0.0%
    mshakir's Avatar
    47677
    Sep 2011
    No 3G service on droid X
    Quote Originally Posted by Concoursrider View Post
    Not sure if this would be of any help, since you already run the hard reset.
    I probably lost 3G for last couple of days and did not notice it until today, since i am using wifi most of the time.
    Anyway, I called VZW tech support and they were able to fix it in minutes.
    Go to setting, then to battery data manager,
    click/select data delivery
    click data enabled and data roaming
    Mine 3G service came up right away. Not sure why they were disabled. I believe data roaming was not turned on earlier anyway. But 'data enabled' why got disabled, no clue about that.
    Also check setting->mobile networks
    Mine shows 'system select' and nothing else
    clicking 'system select' , make sure automatic is selected. This was the first thing tech checked.
    I hope this helps you too.
    for voice call bars, you may want to try *228 to program your roaming.
    By the way, I have droid X with 2.3.3 gingerbread, with no changes to OS. It is like what came from VZW.
    Points: 93, Level: 1
    Level completed: 86%, Points required for next Level: 7
    Joy's Avatar
    47689
    Sep 2011
    I'm having a similar problem. I took a trip to a rural area with limited coverage using my Droid x as a mobile hotspot all the way there. At some point, I lost my data connection and all internet capabilities. I returned home on Labor Day but the data connection could not be reestablished. I have reboot. I have restored to factory default settings. I took the phone in to Verizon and had a tech look at it. I called the phone techs on 4 occasions. I still have no data connection. My mobile hotspot works, but the data connection will connect briefly then disconnect. Any fixes or ideas. Verizon cannot even diagnose the problem. The phone is a year old.
    Points: 48,761, Level: 100
    Overall activity: 17.2%
    gbrinn's Avatar
    38696
    Headed to Duke University Hospital
    17,707
    727 times
    I didn't have a problem with that kind of thing happening until the .596 OTA. Usually doing a battery pull would do the trick for restoring it. If battery pulls and factory resets don't do the trick and unless someone who knows more than I do chimes in with a solution that I'm unaware of, then I'd suggest trying to get a warranty exchange on it.
    "Master of Puppets I'm pulling your strings / Twisting your mind, smashing your dreams
    Blinded by me, you can't see a thing / Just call my name, 'cause I'll hear you scream
    Master / Master
    " - Metallica
    45742
    Aug 2011
    Thank you for all the posts. Unfortunately the issue still hasn't been fixed and I just got off the phone with Verizon and I'm still within my warranty period, so they will be sending out a new phone to me next week.
    45742
    Aug 2011
    One quick thing I should mention, one of the techs told me that some of the anti-virus programs have been known to cause issues with the 3G as well, but after the hard reset, that app was gone and the phone still had problems. Just a FWIW.
    gbrinn's Avatar
    38696
    17,707
    727 times
    You don't need antivirus apps, fyi. Cause more issues and there aren't really any viruses for android, more malicious apps.
    Master / Master
    " - Metallica
  1. Hard Reset without a working Screen?
    By fleetionmedic in forum Droid X Help
    Last Post: 08-17-2011, 03:18 PM
  2. How to Hard Reset?
    By ladydroidx in forum Droid X Help
    Last Post: 02-22-2011, 06:42 PM
  3. hard reset
    By giantsfan91 in forum Droid X Help
    Last Post: 10-28-2010, 10:14 AM
  4. Hard Reset
    By markb in forum Droid X Help
    Last Post: 07-30-2010, 01:58 PM
  5. hard reset?
    By silent1643 in forum Droid X Help
    Last Post: 07-17-2010, 08:54 PM
3g not working after factory reset
droid 3 data not working
droid 3g not working
droid x 3g not working
droid x no 3g after factory reset
droid x no service after factory reset
droid x will not connect to 3g
droid x wont connect to 3g
my droid x 3g not working
system reset 3 g not working
