Incompatible Apps
This is a discussion on Incompatible Apps within the Droid X Help forums, part of the Droid X Discussion category; Hey, i'm running liberty rom v.9 with the latest gingerbread and lately i've noticed that a lot of apps are incompatible in the android market. ...
Results 1 to 9 of 9
  • 1 Post By th30n37
Thread: Incompatible Apps
    Points: 711, Level: 14
    Level completed: 11%, Points required for next Level: 89
    Tagger Second Class3 months registered100 Experience Points31 days registered7 days registered
    hochoch's Avatar
    29477
    Incompatible Apps
    Hey,
    i'm running liberty rom v.9 with the latest gingerbread and lately i've noticed that a lot of apps are incompatible in the android market. like IMDB, Facebook, Friendcaster, Words w/ Friends and more. Anyone know why this is or how i can fix it?! i tried both the phone and web versions. Is it because i'm rooted?! I was able to download some off the amazon market, but not all are available there. Thanks!!!
    Points: 1,695, Level: 23
    Level completed: 95%, Points required for next Level: 5
    th30n37's Avatar
    8322
    25
    From what I have read, it seems like it is a lcd density problem. The new market is being much more strict on what apps are "compatible" with devices now. There are a guides on the internet detailing how to change it back to the stock, clearing the market data, and then restoring the density back to your preferred value.
    Today I just went back to the old market version and it took care of the problem. FWIW I'm on Liberty v.8 and the same thing happened on my CM7 Nook Color as well. Hopefully someone else can chime in with more info though.
    pool_shark likes this.
    Points: 912, Level: 16
    pool_shark's Avatar
    31799
    Ohio
    202
    Quote Originally Posted by th30n37 View Post
    I haven't read that. I was trying to download an app yesterday and it said it was incompatible. I just changed the density back to normal and just downloaded the app.
    Thanks a lot.
    Edit:
    I also had 9 app updates after the change.
    DX GB .588 OC LV 1.3.
    hochoch's Avatar
    29477
    thanks for your replies - much appreciated!!! i never modified my screen density though? Pool_shark - what did you change?!
    hochoch's Avatar
    29477
    UPDATED - i did some googling and found this app: https://market.android.com/details?id=lv.n3o.lcddensity i set my density to 240dpi from 235, rebooted, cleared market data and now 31 new updates are showing up! Including ones i couldn't update yesterday. Thanks very much for pointing me in the right direction!!!!
    pool_shark's Avatar
    31799
    Ohio
    202
    Quote Originally Posted by hochoch View Post
    I changed mine from 200 to 240.
    Points: 757, Level: 14
    Level completed: 57%, Points required for next Level: 43
    Overall activity: 0.7%
    frederico265's Avatar
    25493
    12
    OMG! So helpful! I couldn't download apps and after i fixed my density and cleared the data it's back.
    Thanks so much!
    Points: 826, Level: 15
    Level completed: 26%, Points required for next Level: 74
    el80ne's Avatar
    21614
    Xanadu
    7
    Exclamation Pretty weak tea that I can't use my desired density setting though ...
    I love scrunching as many apps as possible on my desktops and it's pretty sad that I have to blow my screen up like a balloon in order to install and update incompatible apps.
    Anyone know of a good workaround?
    I'll try using an older market. Does anyone know the most recent market version that won't throw a hissy fit about incompatibility and where to find it?
    Thx for any info should someone be able to provide it.
    Points: 15,172, Level: 79
    Overall activity: 14.0%
    cory46's Avatar
    8051
    4,768
    125 times
    Quote Originally Posted by el80ne View Post
    Most apps are created and submitted to the market with a screen density in mind (ldpi, mdpi, hdpi and tablet) so when you change your screen density the market reads usually your build.prop and displays compatible apps.
    So it's not so much the market it's a combination of you changing your density and the app developer creating the app with a certain density in mind. So even if your market allowed the download the manifest of the app would still call for a certain density ( which you would no longer have)
  1. Droid X force closing multiple apps and not saving new apps
    By bballfan77 in forum Droid X Rescue Squad
    Last Post: 07-16-2011, 08:27 AM
  2. Widget locker incompatible with music player
    By intelo2 in forum Droid X Rescue Squad
    Last Post: 06-21-2011, 06:09 PM
  3. Amazon Apps showing in My Apps of Market
    By scost23 in forum Droid X Rescue Squad
    Last Post: 06-16-2011, 09:48 AM
  4. Apps and services incompatible with gingerbread leak.
    By scottpole in forum Gingerbread General Discussion
    Last Post: 04-26-2011, 08:42 PM
  5. Replies: 9
    Last Post: 09-22-2010, 01:20 PM
can't download facebook for android incompatible
facebook not compatible with root liberty
fix your device is not compatible with this item in android app market
nook color cm7 your device is not compatible with this item
this app is incompatible with your unknown m711
why are apps not compatible with droid x
why are some amazon apps not compatible with
your device is incompatible with this item
your device is not compatible with this item nook color cm7
your device is not compatible with this item screen density
