How to get rid of smiley symbol on keyboard
This is a discussion on How to get rid of smiley symbol on keyboard within the Droid X Help forums, part of the Droid X Discussion category; Is there a way to get rid of that smiley symbol on the keyboard on the DX? I'm a guy and have never used a ...
Results 1 to 10 of 10
Thread: How to get rid of smiley symbol on keyboard
    3 months registered100 Experience PointsTagger Second Class31 days registered7 days registered
    tkolgen's Avatar
    2588
    San Diego
    17
    Is there a way to get rid of that smiley symbol on the keyboard on the DX? I'm a guy and have never used a smiley in a text message before. I don't know why they felt like they had to put a shortcut to it right were the enter button should be.
    I'm coming from a BB and that is where the enter button was on my last phone and that was how I sent text messages. It's pretty annoying that a smiley symbol is there now since every time I want to send a text my initial instinct is to go to that place on the keyboard.
    I just want it removed so I don't include it in any of my messages.
    Thanks
    Points: 10,255, Level: 67
    Backnblack's Avatar
    26
    2,816
    139 times
    The stock keyboard does not have that option. I use handcent for SMS and it will replace the keyboard, instead of smiley's you'll have a return key.
    Only the Skilled Survive
    1. Never be unarmed.
    2. See Rule #1
    Points: 27,939, Level: 98
    Abe21599's Avatar
    Ohio
    4,864
    459 times
    or just try out a different keyboard. better keyboard & swiftkey are two i have
    Points: 77,892, Level: 100
    Overall activity: 71.7%
    20,509
    885 times
    In handcent, you can toggle between the Smiley/return key. While in handcent press the hardmenu key, select settings, application settings, scroll to action key type & make selection.
    Sent from my Droid X
    tkolgen's Avatar
    2588
    San Diego
    17
    Thanks for all of the suggestions. I Downloaded a couple different apps.
    Points: 2,023, Level: 27
    Level completed: 16%, Points required for next Level: 127
    pastrygirl's Avatar
    874
    95
    13 times
    Does Swype have a different keyboard, because I don't see a smiley face...?
    20,509
    885 times
    Quote Originally Posted by pastrygirl View Post
    If you are using Handcent - you can add smiley's to any keyboard (switch between the return key and smiley faces)...
    Points: 1,207, Level: 19
    Level completed: 7%, Points required for next Level: 93
    iceclimbr's Avatar
    14649
    Epic Suburban Spawl of Philadelphia
    17
    I'm having the exact same issue. I just came from a BB as well and I'm constantly including that stupid icon in many of my text messages. I'm not a "smiley face" kinda guy. I'll try some of these 3rd party apps. I read another thread that had some comments about disabling the stock SMS application and its notifications. Can someone post some information about doing that? Or isn't it necessary? Thank you.
    20,509
    885 times
    Quote Originally Posted by iceclimbr View Post
    If you download and use Handcent as your SMS app...you can go into the stock SMS app and uncheck notifications so that you do not get duplicate notifications (open stock app, hard menu key, settings, uncheck notifications)...
    iceclimbr's Avatar
    14649
    17
    Downloaded Handcent SMS...its awesome. Much better than the stock SMS app....
  1. HTC Keyboard on the X
    By Legacy23 in forum Droid X Apps
    Last Post: 01-08-2011, 03:20 AM
  2. Keyboard changed
    By thom71gt in forum Droid X Help
    Last Post: 08-06-2010, 03:38 PM
  3. Keyboard
    By TTGTOVR4 in forum Droid X Apps
    Last Post: 08-03-2010, 11:08 PM
  4. Htc_ime keyboard?
    By supahrob in forum Droid X Apps
    Last Post: 08-03-2010, 11:21 AM
  5. Better Keyboard - Font?
    By statik in forum Droid X Help
    Last Post: 07-26-2010, 07:55 PM
android keyboard remove smiley key
get rid of smiley on android keyboard
how to get phone virtual keyboard to return key from smiley face?
how to get rid of smiley button on android keyboard
how to get rid of smiley face on android
how to get rid of the smiley face button on android keyboard
how to remove smiley face from android keyboard
how to remove smiley from android keyboard
remove emoticons android keyboard
