Help! Screen turned yellow and froze!
This is a discussion on Help! Screen turned yellow and froze! within the Droid X Help forums, part of the Droid X Discussion category; I have a DX (rooted a few days ago) and until now no problems. I have had Launcherpro loaded for about a week and about ...
Results 1 to 8 of 8
  • 1 Post By smalltowngirl13
Thread: Help! Screen turned yellow and froze!
    Points: 5,913, Level: 49
    stevewitt's Avatar
    2914
    Lake Station, In
    452
    18 times
    I have a DX (rooted a few days ago) and until now no problems. I have had Launcherpro loaded for about a week and about an hour ago updated to Plus. My first thought was to change a few icons. I did a long press on the screen to add an app and when I did the screen turned a yellowish color and froze. Can't switch screens, launch apps, nothing. I powered down and then powered up again and everything seems fine, so I tried it again, same results. Again rebooted and all is fine. Including pictures (taken with my girlfriend's X so that you can see normal screen and yellow screen. Sorry about the focus. Anyone have any thoughts on this? TIA
    Attached Images Attached Images
    Points: 27,939, Level: 98
    Abe21599's Avatar
    Ohio
    4,864
    459 times
    so is everything fine now? i use LP and havent encountered that problem.
    Points: 4,469, Level: 42
    Level completed: 60%, Points required for next Level: 81
    BOWIE's Avatar
    1078
    Scottsdale, AZ
    603
    39 times
    I don't know what to say other than it sounds like a launcher pro plus quirk.
    stevewitt's Avatar
    2914
    Lake Station, In
    452
    18 times
    Quote Originally Posted by Abe21599 View Post
    Everything's fine as long as I don't do a long press on the screen.
    X Pursuant Achievements:
    movadoevo8's Avatar
    628
    591
    8 times
    Can u revert and unroot? So u can test?
    Points: 77,892, Level: 100
    Overall activity: 71.7%
    20,509
    885 times
    Steve - on the yellowish screen do you see the gray corner on the bottom right...it put your screen into "resize widget" mode - if it happens again, press your back arrow...what is on your screen? LPP is trying to resize a widget but I didn't see a widget...
    stevewitt likes this.
    stevewitt's Avatar
    2914
    Lake Station, In
    452
    18 times
    Bingo, that did it! I did the long press on a blank screen as you can see and I guess LPP assumed I wanted to re-size the whole screen. Hitting the back button took me right back to normal. Thanks a million, I was freakin' out!! All hail the Droid X goddess smalltowngirl13!!!!!!!!!
    20,509
    885 times
    Quote Originally Posted by stevewitt View Post
    You are too kind ...I don't understand tho why it was wanting to resize the whole screen - I have not had that happen - that part is odd...I haven't heard of anyone else here (altho I could have missed it) having that problem...maybe I will go check the LP forums and see if it was reported..if it is a bug, you can bet the dev (if aware, will have it fixed in no time)...Does it do it to all your screens? If so, drag it to the smallest area possible and hit backspace & then see if you can add a widget in any other part...
  1. Turned on phone-down 10% since charge
    By AsterDroid in forum Droid X Help
    Last Post: 08-09-2010, 10:42 AM
  2. DX froze up for the first time
    By brosselle in forum Droid X General Discussion
    Last Post: 08-05-2010, 05:40 AM
  3. Replies: 3
    Last Post: 08-04-2010, 11:09 AM
  4. my x turned on/off automatically..anyone the same?
    By puffy98 in forum Droid X General Discussion
    Last Post: 07-25-2010, 01:51 PM
  5. They turned the charging port upside down
    Last Post: 07-15-2010, 10:53 PM
droid phone yellow screen
entire tablet screen turned yellow
galaxy tab froze on yelliw screen
how to turn back to normal my android yellowish screen
my phone screen is freezing and then turns yellow
my phone screen is yellow
my phone screen turned yellow
my phone turned yellow
phone screen turning yellow
why is my phone screen yellow
