Anyone else having wifi connection drops on roms based on android 2.3.5?
This is a discussion on Anyone else having wifi connection drops on roms based on android 2.3.5? within the Droid X Help forums, part of the Droid X Discussion category; Sbf'ed last night with intentions to install miui 1.8.5, from 1.7.29, I figured I'd download latest cm7 nightly and see what it was like since ...
Results 1 to 1 of 1
Thread: Anyone else having wifi connection drops on roms based on android 2.3.5?
    Points: 2,189, Level: 28
    Level completed: 26%, Points required for next Level: 111
    Overall activity: 4.7%
    fnmetal's Avatar
    35394
    new haven CT
    668
    15 times
    Sbf'ed last night with intentions to install miui 1.8.5, from 1.7.29, I figured I'd download latest cm7 nightly and see what it was like since I haven't ran one in a while.. well I couldn't at all maintain wifi connectivity for 5 mins at a clip.. couldn't download miui 1.8.5 through rom manager kept failing because my signal kept cutting out.. so I flashed miui 1.7.29 right over cm7, no wifi issues, downloaded 1.8.5 wiped everything and installed, wifi issue started again.. figured I'd sbf and install 1.8.5 fresh off an sbf, still same result, wifi drops out; flashed 1.7.29 over 1.8.5, now wifi is fine.. I'm assuming it has something to do with my hardware (phone or router), and android 2.3.5.. any suggestions, or anyone else experience this?
    with Google ™
  1. Voicemail on cm7 based Roms. Help Please!
    By silver04v in forum Gingerbread Roms
    Last Post: 07-31-2011, 09:32 PM
  2. Bootloader limiting cm7 based roms at all?
    By Dvan in forum Cyanogenmod
    Last Post: 07-20-2011, 05:45 AM
  3. Bootloader limiting cm7 based roms at all?
    By Dvan in forum Gingerbread Roms
  4. WiFi drops Radio Signal
    By Cigator in forum Droid X Help
    Last Post: 07-11-2011, 09:38 PM
  5. Wifi drops when streaming on YouTube
    By dAi in forum Droid X Help
    Last Post: 02-17-2011, 10:00 PM
android 2.3.5 wifi
android 2.3.5 wifi issues
android 2.3.5 wifi problem
android dropping wifi
android drops wifi connection
droid x drops wifi
droid x wifi drops connection
miui dropping wifi
miui drops wifi
