GB-Phone Issues
This is a discussion on GB-Phone Issues within the Droid X Help forums, part of the Droid X Discussion category; I haven't had any problems with my phone since the upgrade but yesterday my phone started automatically hanging up whenever I try to make a ...
Thread: GB-Phone Issues
    Points: 682, Level: 13
    Level completed: 64%, Points required for next Level: 18
    PatM's Avatar
    43458
    Jul 2011
    Austin TX
    12
    GB-Phone Issues
    I haven't had any problems with my phone since the upgrade but yesterday my phone started automatically hanging up whenever I try to make a call. Once this happens, the only way to restore it is to Power Off/On. I thought it might have been a one-time issue but it happened twice yesterday and twice today. I am running stock GB and haven't installed any new apps. Has anyone else encountered this bug? Any help would be appreciated.
    Pat M
    Points: 10,712, Level: 68
    Level completed: 66%, Points required for next Level: 138
    Dustin0308's Avatar
    24203
    1,490
    37 times
    Hmm..I don't have an x anymore but you could try a battery pull. Pull the battery, lv it out for like 30 secs to a minute then see how that helps. If that doesn't help, you can try a factory reset.
    Sent from my Thunderbolt using Droid X Forums
    PatM's Avatar
    43458
    Jul 2011
    Austin TX
    12
    I guess it's just a "Wait for the update" since no one replied.
    Pat M
    Points: 17,929, Level: 85
    Snow02's Avatar
    22940
    3,769
    142 times
    Factory reset. That will fix it.
    Themer
    Points: 4,766, Level: 44
    Level completed: 8%, Points required for next Level: 184
    nemosfate's Avatar
    27305
    cincinnati
    1,080
    20 times
    Quote Originally Posted by PatM View Post
    Good to let someone know if something worked to try more options, not trying to be rude just saying, they could have assumed you got it cleared up with the battery pull
    root, roms and themes oh my!
  1. Serious issues with my phone
    By DoWork44 in forum Droid X ROMs
    Last Post: 06-16-2011, 11:01 AM
  2. Replies: 131
    Last Post: 02-18-2011, 04:01 AM
  3. Phone Number Issues
    By carosati3 in forum Droid X Help
    Last Post: 10-10-2010, 11:24 PM
  4. Phone having issues
    By phil0352 in forum Droid X Help
    Last Post: 09-24-2010, 12:32 AM
  5. Phone having issues
    Last Post: 09-23-2010, 11:21 PM
gb phone
