Water Damage Troublshooting
This is a discussion on Water Damage Troublshooting within the Droid X Help forums, part of the Droid X Discussion category; My friend gave me a DX that she had dropped in coke. She took out the battery and let the little guy sit in rice ...
Thread: Water Damage Troublshooting
    Tagger Second Class
    Skyeba's Avatar
    44856
    Aug 2011
    My friend gave me a DX that she had dropped in coke. She took out the battery and let the little guy sit in rice for a few days, and then it seemed to boot up ok. When she gave it to me, it ran for about 20 minutes, got very hot, and then died.
    I opened it up and cleaned out the sugar and gunk with 91% rubbing alcohol and q-tips, and then let it dry. Now, it will sometimes boot but soon turn off, and other times it will begin to charge from 0% or 10% but then die again.
    I bought a new battery for it but doesn't seem to make a difference.
    Does anyone have advice? Is there a particular part I could replace or have I done something to damage it aside from the coke fiasco?
    Help is much appreciated, thank you!
    Points: 5,591, Level: 48
    Level completed: 21%, Points required for next Level: 159
    zoe's Avatar
    9237
    lost angels
    1,429
    33 times
    dropping a phone into water is bad, but into coke is way worse. I'm surprised it even booted at all. i don't think there's anything you can do at this point, if even a tiny bit of the coke got into areas that you can't readily access (which really is most of the phone and it's internal components) there could be corrosive damage or some gummed up sticky residue. water would evaporate completely (well not really) whereas coke would leave all sorts of things. saltwater would be just as bad.
    a grade school teacher showed us the corrosive powers of soda once, so again i think it's likely this dx has gone on to better places
    Tagger Second Class
    Skyeba's Avatar
    44856
    Aug 2011
    But while it still boots and gasps for life, I can not simply write it off as a lost cause.
    drop it in water to clean the sticky stuff out and then dry it =P
  1. Water damage
    By Enyo in forum Droid X Rescue Squad
    Last Post: 07-25-2011, 02:25 PM
  2. Some Water Damage
    By sam7959 in forum Droid X Help
    Last Post: 07-20-2011, 11:29 PM
  3. Droid x water damage
    By aeboarderus in forum Droid X Help
    Last Post: 06-22-2011, 08:14 AM
  4. Water damage
    By LAKingsFan24 in forum Droid X Help
    Last Post: 06-10-2011, 09:43 PM
  5. water damage with X
    By hunter7m in forum Droid X Help
    Last Post: 01-13-2011, 08:46 PM
droid x salt water
droid x water
droid x water damage repair
droid x2 water damage
droid x2 water damage repair
droud x saltwater
how to fix a water damaged droid x
how to fix water damaged droid X
motorola droid x2 water damage phone gets hot
