Freezing keyboard
This is a discussion on Freezing keyboard within the Droid X Help forums, part of the Droid X Discussion category; Okay well, I was using my phone as normal one day. And then all of a sudden it started freezing when I used punctuation. I ...
Results 1 to 7 of 7
Thread: Freezing keyboard
    Freezing keyboard
    Okay well, I was using my phone as normal one day. And then all of a sudden it started freezing when I used punctuation. I can't use the multi-touch keyboard to type a period, exclamation mark, or double tap the spacebar for a period. If I do try to use them my phone will freeze. Then I tried to use the home button to disregard it, and the keyboard is shown on the home screen. The only way to get rid of it is to turn the phone completely off with a battery pull. I have restarted and pulled that battery out for several minutes and the problem continues. I've tried rebooting the phone, but nothing has worked. For now I am teaching myself how to use swype because that is the only thing that works. Please help.
    Points: 45,915, Level: 100
    Posting Award
    macpro88's Avatar
    20491
    6,966
    322 times
    From the home screen; menu key, settings, applications, manager applications, all applications, find keyboard and tap on clear cache, if that won't fix it, go back and clear data as well.
    DroidXForums Guidelines of Conduct
    Show Your Support and Become a Supporting Member Today!
    I tried what you told me, and I don't have the option to clear cache, should I just clear data?
    Posting Award
    macpro88's Avatar
    20491
    6,966
    322 times
    Do just data then, then reboot.
    I just rebooted my phone and everything seems to be working fine. Thank you!
    Posting Award
    macpro88's Avatar
    20491
    6,966
    322 times
    No problem, glad to help!
    Points: 224, Level: 4
    Level completed: 48%, Points required for next Level: 26
    100 Experience Points3 months registered31 days registered7 days registered
    Becky's Avatar
    44744
    Jul 2011
    Thank you from me, also....I had the same problem today and tried your solution. So far, so good....
  1. Freezing/lagging/ keyboard issues
    By Jdsalon4u in forum Droid X Stock Issues
    Last Post: 07-18-2011, 09:18 PM
  2. Replies: 0
    Last Post: 07-14-2011, 09:07 AM
  3. Changed battery and now keyboard keeps freezing, help?
    By blownsti in forum Droid X Help
    Last Post: 07-06-2011, 07:30 PM
  4. Replies: 1
    Last Post: 06-13-2011, 07:22 PM
  5. Replies: 9
    Last Post: 11-10-2010, 10:16 PM
droid 2 keeps freezing
my droid keyboard keeps freezing
my keyboard keeps freezing
my motorola atrix keeps freezing
why does my android keyboard keep freezing
why does my droid keyboard keep freezing
why does my droid x2 keep freezing
why does my motorola atrix keep freezing
why does my phone freeze
why is my atrix freezing when i use punctuation
