Inserting pauses and DTMF tones into Voicemail contact
This is a discussion on Inserting pauses and DTMF tones into Voicemail contact within the Droid X Help forums, part of the Droid X Discussion category; So, in my contacts list, I altered my voicemail number to include pauses, and my password, so I don't have to enter it manually when ...
Results 1 to 8 of 8
Thread: Inserting pauses and DTMF tones into Voicemail contact
    hear my name's Avatar
    5009
    5
    So, in my contacts list, I altered my voicemail number to include pauses, and my password, so I don't have to enter it manually when I dial. When I open the dialer and hold down 1 (voicemail speed dial), the number dials, pauses, and sends the DTMF tones for my password, no problem.
    But, when I open up the recent calls list and redial the voicemail number from that list, the DTMF tones aren't sent. It just dials *86 and waits for me to enter my password.
    Also, when I open up the Voicemail app and call voicemail from there, it's the same thing. Just *86 and no tones.
    The only time the DTMF tones work is when I call voicemail by holding down the 1.
    Is there a way to make the phone dial the number with pauses and tones universally, no matter what method is used to dial it?
    Points: 10,255, Level: 67
    Backnblack's Avatar
    26
    2,816
    139 times
    Home Screen>>Menu>>Call Settings>>voicmail settings
    Change it there
    Only the Skilled Survive
    1. Never be unarmed.
    2. See Rule #1
    5009
    5
    Quote Originally Posted by Backnblack View Post
    Change it there
    It shows up with the pauses and tones in Home Screen>>Menu>>Call Settings>>voicmail settings. Looks like it should be working fine, but it still only sends the tones when calling from speed dial or directly from the contacts list.
    When I call from the voicemail app, still no tones. Or even redialing from the recent calls list, no tones are sent.
    Points: 1,714, Level: 24
    Level completed: 14%, Points required for next Level: 86
    Barkdog's Avatar
    5242
    10
    Same problem! I've tried one, two, even three pauses [and then my access code] in the "Home Screen>>Menu>>Call Settings>>voicemail settings" input box. But when I dial voicemail from the voicemail app on my home screen, it just dials *86 --no pauses, no code. Anyone know the solution? Thanks much.
    5009
    5
    Quote Originally Posted by Barkdog View Post
    I still haven't found a solution for this. Although, I did find that it dials the pauses/tones properly when checking voicemail from the notifications bar. Still no luck from the voicemail app or redialing from recent calls list.
    I ultimately went with Google Voice to handle my voicemail, so I don't even have to call it anymore.
    MrMikeM513's Avatar
    4936
    10
    Looks like yet another in a long list of FroYo update bugs. In 2.1, the pause dialing worked no matter where you initiated it.
    How do you report a bug to Verizon directly?
    I worked around it by wiping the VM entry in my address book, re-entering it with the pauses and my pin... then using the Motorola quick contact task widget to add it to my desktop. Now I have one-touch VM with pauses and pin.
    5009
    5
    Quote Originally Posted by MrMikeM513 View Post
    This was actually a bug for me before Froyo. Since I moved to Google Voice to handle voicemail, I haven't played with it after the 2.2 update.
  1. Howdaya assing ring tones to contacts
    By captainwillie in forum Droid X Help
    Last Post: 08-12-2010, 07:28 PM
  2. How do I put in Pauses on phone number?
    By ImaPappy in forum Droid X General Discussion
    Last Post: 08-03-2010, 02:20 PM
  3. Voicemail Greetin
    By redwinger2001 in forum Droid X Help
    Last Post: 07-28-2010, 10:50 PM
  4. Weird tones when calling or receiving a call.
    By timborocksloud in forum Droid X Help
    Last Post: 07-27-2010, 01:36 PM
  5. A few tones
    By ugadawg67 in forum Droid X Ringtones
    Last Post: 07-23-2010, 10:30 AM
DTMF pause
droid x voicemail no tones
dtmf pause tone
dtmf tone pause
dtmf tones pause
pause dtmf android
touch tone pause
voicemail pause droid x
what is dtmf tones on droid
windows phone dtmf
