Syncing Calendar & Contacts on Droid X
This is a discussion on Syncing Calendar & Contacts on Droid X within the Droid X Help forums, part of the Droid X Discussion category; Is there a recommended software to use to sync contacts and calendars? Coming from the world of iPhone, used to using iCal and Address Book. ...
Results 1 to 10 of 10
Thread: Syncing Calendar & Contacts on Droid X
    judgemantx's Avatar
    4899
    Is there a recommended software to use to sync contacts and calendars? Coming from the world of iPhone, used to using iCal and Address Book. I now have everything set up utilizing google.
    medicscott's Avatar
    3362
    san diego
    197
    7 times
    i just came from iphone life too...
    with ical, you can import all these using the online google calender program, makes it real easy!!
    as far as contacts go, your 'address book' is now online at gmail.com and will sync auto daily i believe!
    once you get the hang of the learning curve, you will really enjoy the android OS
    Points: 77,892, Level: 100
    Overall activity: 71.7%
    20,509
    885 times
    Quote Originally Posted by judgemantx View Post
    Welcome to the forums!! Once you are setup with google, your phone should automatically sync your contacts and calendar. You can edit them on your phone or in your google.com account on a computer and they will update in the next sync cycle. And your world just got a whole lot bigger - glad ya found us!!
    RichieP's Avatar
    22223
    13
    Yeah, but... Getting the info from iCal to google calendar is the problem. Sure you can either import or export the calendar. But how do you get it to sync. with every change made on either the desktop or the handheld device?
    cjpinkz2's Avatar
    26467
    5
    Yea looking for the same thing here want added events to sync b/n ical, google and droid x without having to constantly export and import. Is it possible to do?
    20,509
    885 times
    I am not sure this link will help you but it might...
    Get Started with CalDAV - Google Calendar Help
    Points: 5,156, Level: 46
    Level completed: 3%, Points required for next Level: 194
    Overall activity: 2.8%
    bobniborg's Avatar
    7200
    381
    I use Jorte for my calendar on my phone and anytime I update the calendar on the phone or on google, it adds it to both my phone and my wife's phone. It autosyncs. Can you not find the auto sync feature or am I misunderstanding the problem?
    MattRush's Avatar
    26537
    5
    I'm having the same problem. When I add things to the calendar on my phone it will show up in iCal, but nothing I put on iCal shows up on my phone. I've been playing with it for a few months and can't figure out how to make it work.
    RichieP's Avatar
    22223
    13
    Some have responded that this is easy, but in fact it takes some outside third party app. You can try "The missing sync" which works will but requires using USB and manually activating the sync. There is "SyncMate" which work flawlessly until they fixed it until it was broken, with version 3.0 and now I can not use it. They have poor to none technical support. The complication comes from how many calendars you have. Apple made this over complicated, by allowing users to created multiple calendars. When you set up the sync you have to know which calendars are selected to sync.
    I have been using the droid for about 1 month and will be first in line with the Verizon iphone. The problem is no one really knows all the quirks to get a Mac to sync with a droid. The iphone is seemless and far less complicated.
    Points: 1,784, Level: 24
    Level completed: 84%, Points required for next Level: 16
    dtsig's Avatar
    17218
    Oregon
    191
    7 times
    This is why there will always be apple products. The android phone has to be all things to all people ... work with all existing sw etc. But apple only has to write specifically to their hw/sw. Makes life pretty easy peasy
  1. Syncing with Outlook Contact & Calendar
    By pumpbubble in forum Droid X Help
    Last Post: 09-18-2010, 12:31 PM
  2. Syncing google contacts
    By ap3100 in forum Droid X General Discussion
    Last Post: 08-06-2010, 11:06 PM
  3. Google Calendar syncing?
    By fobulous in forum Droid X General Discussion
    Last Post: 08-03-2010, 11:15 PM
  4. Contacts not syncing via Bluetooth
    By riguy in forum Droid X General Discussion
    Last Post: 07-19-2010, 11:50 AM
  5. Help with Facebook syncing contacts...
    By nowski91381 in forum Droid X General Discussion
    Last Post: 07-15-2010, 05:37 PM
How to sync Ical with droid x
droid x contact sync
droid x contacts sync
droid x sync contacts
how to email droidx call log sync
how to sync ical to droid x
ical for droid x
sync ical with droid x
syncing ical with droid x
