Bluetooth Advice Urgently Needed
This is a discussion on Bluetooth Advice Urgently Needed within the Droid X Help forums, part of the Droid X Discussion category; I am a total Newb, and am not at all technologically inclined. I have a Droid X. I'm looking for a hands-free device, and am ...
Results 1 to 9 of 9
Thread: Bluetooth Advice Urgently Needed
    7 days registeredTagger Second Class
    DroidXGirl1's Avatar
    41913
    9
    I have a Droid X.
    I'm looking for a hands-free device, and am also in the market for a new car charger. (ability to listen to radio/Pandora through my car speaker is a bonus, but not necessary). I'm not a big fan of ear-pieces or a lot of cords running all over the place.
    Does anyone have experience with the T505 or Jabra Cruiser2 or H17txt?
    I like the fact that the Jabra cruiser2 tells you the name of the caller, but it seems like it's more complicated to operate than the T505. Are these models hard to work?
    Can you charge your phone with them too, or do you need a separate cord for the BT and for the Droid?
    Do you have to remove the units to charge them, or can you charge them in the car?
    Any pros/cons of different models would be greatly appreciated.
    Last edited by DroidXGirl1; 06-28-2011 at 02:54 PM. Reason: Added additional information
    Points: 1,116, Level: 18
    pharmnatr's Avatar
    29462
    144
    Jawbone Icon is the best I've used and I have had 4 or 5 different headsets. It streams music using a2dp. It gets 4 hours of talk time and its small enough that it stays in my ear without using a loop. It charges with the same connector that your phone uses - micro usb. Jawbone makes a newer model that is slightly longer and heavier. Its heavier because the battery is a little larger and I believe it gets 5 hours of talk time.
    Points: 2,861, Level: 32
    e3zkiel's Avatar
    6303
    California
    216
    11 times
    Quote Originally Posted by pharmnatr View Post
    The larger model also has an accelerometer! Sweet! Haha. Anyways, I have been using the Icon since it's initial release and only had 1 problem. Wind resistance while walking. It's wind protection is far superior to it's original model but I believe it still needs work for windy areas; especially if you walk outside while you talk on the phone. Great Bluetooth device!
    Nokia handheld -> LG flip phone -> Storm -> Droid X
    ROOTED and lovin' it
    running Android
    4.0.4 - currently using Gummy 1.2.0 - 5/9/12 [BETA]
    Points: 35,547, Level: 100
    Overall activity: 42.3%
    1KDS's Avatar
    3981
    6,904
    572 times
    Moving thread to Droid X Help forum.
    41913
    9
    Any advice for a non-earpiece hands-free model?
    Points: 9,907, Level: 66
    ToeJamm57's Avatar
    6466
    Michigan
    2,463
    64 times
    I have my DX mounted to a window mount when I drive. I frequently listen to audiobooks and have the phone plugged into my auxillary jack in the car stereo. I am able to talk using only the phone (hearing voice over the radio). Callers tell me my voice is clear and understandable (and I drive a pickup so you can imagine the background noise).
    I also use an app called Vlingo which allows me to use voice commands to call, etc.
    I have not used a blue tooth device since I got this phone.
    Quote Originally Posted by DroidXGirl1 View Post
    Tagger Second Class
    RJisCaboose's Avatar
    42137
    Woodbridge, VA
    5
    OP I use the t505. I have left it in the car on massively hot days, in the dead of winter, I am a smoker and it sits right above my head...basically I put the thing through hell. It is a GREAT piece. There are three things that will drive you nuts, however, but if you can get by the annoyance you'll love it. 1. When searching for a clear station for the fm transmitter to broadcast on...you can only hit the auto scan button (i.e. no manual control over the freq). However, the auto scan doesnt "listen" for an open channel it just chooses one (often with terrible results). A little bit of patience will see this problem through. 2. When driving with the FM transmitter off (which it will do if u dont talk on it for a while) and a call comes in, you cant just reactivate the fm transmitter and start talking. you must answer the phone, ask the person to hold on, hit the button and wait for the british lady voice to finish saying the frequency twice, THEN you can talk. Thats the only one that makes me insane lol. 3. and the only other small bit of annoyance is there is a few second delay between when the phone does something and when the system can speak to you. This is only annoying when using the turn-by-turn nav on the phone. Some of the shorter direction commands get lost.
    Dont get me wrong about all that, it IS a great piece! Im sure all models have some small annoyances like that! Good luck.
    41913
    9
    Thanks for all the advice. I ended up getting the Jabra Cruiser2, because I don't like ear pieces, and the feature I liked on the Jabra that the T505 doesn't have is that it theoretically links up to your contacts and will announce the name of the caller, rather than just the telephone number. I called someone today, and the voice activated commands worked well, and the call was clear as a bell, and I was told that this was the best audio they've had with me using my Droid X, even though I was driving at the time. The noise cancellation feature appears to work well.
    I haven't gotten a chance to link it to my radio yet, or try Pandora, but I'll post about that once I've tried. Hopefully it will be as easy as it was to link and set up the Jabra Cruiser2.
    This was my very first bluetooth, and it was so easy, that even I had no trouble doing it.
    I also liked that I was able to charge it using my laptop. It charged very quickly (about an hour). We'll see how much talk time it takes to use up that charge.
    Thanks again, all!
    41913
    9
    To update you on my experience with Jabra Cruiser2...
    It was a snap to set up. Just charged it, put my Droid X on bluetooth mode, turned on the Cruiser2, and that was pretty much it.
    Problems: 1) It doesn't announce the names of callers, just the telephone numbers. As that was a feature I interested in, when I spoke to CS, they said that because my contacts contain info like photos, emails, addresses, there is a glitch. They are working on it, and hope to have a patch. However, if a contact only has a phone number and name, it will announce by name rather than number (theoretically).
    2) I wanted to listen to Pandora through my radio. Again, easy to set up. Turn on Cruiser2. Press FM button. it tells you what station to set your radio on, and hey presto! It comes through. However, I was getting static. CS said that if I press FM and hear the announced frequency, I can then press Volume+ or Volume- to change the announced connection frequency, to find a clearer station.
    So, I'm all hands-free and legal these days, which is a good thing, and don't have to fuss with an ear piece.
  1. Advice on bluetooth stereo?
    By tracey in forum Droid X Audio / Video
    Last Post: 09-14-2011, 07:42 AM
  2. Bluetooth With head unit(have to cycle bluetooth to get it to connect)
    By pheonix991 in forum Droid X General Discussion
    Last Post: 04-12-2011, 03:40 AM
  3. Bluetooth issues (recently acting up with vehicle bluetooth interface)
    By buzzdroidblitzz in forum Droid X General Discussion
    Last Post: 12-13-2010, 05:52 PM
  4. Advice on buying Bluetooth visor devise for my car
    By Sfeingold12 in forum Droid X General Discussion
    Last Post: 08-17-2010, 05:54 PM
  5. help needed: bluetooth receiving
    By bouny1920 in forum Droid X Help
    Last Post: 07-16-2010, 10:30 PM
bluetooth not working with droid x
bluetooth works off and on droid x2 static noise
can droid x play pandora through car bluetooth
droid voice dialer connection to headset lost
droid x not playing pandora bluetooth car
droid x remove bluetooth profile
droid x set up pandora to bluetooth
jabra cruiser 2 doesn't announce name
jabra cruiser 2 play audiobook
update bluetooth profiles droid x
