Android OS draining battery???
This is a discussion on Android OS draining battery??? within the Droid X Help forums, part of the Droid X Discussion category; Originally Posted by njabler Also, I lost my Droid X Forum app...it's as if I didn't download it at all. The DroidXForum app installs to ...
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Android OS draining battery???
    Natey2's Avatar
    19853
    112
    8 times
    Quote Originally Posted by njabler View Post
    The DroidXForum app installs to SD by default, I think.
    I once noticed it missing when hooked up via USB, and SD was not available.
    I moved the app back to the phone.
    Is your SD card mounting fine?
    Sent from my unrooted DroidX using DroidXForums app.
    Points: 971, Level: 16
    Level completed: 72%, Points required for next Level: 29
    MEANFIST's Avatar
    46746
    Aug 2011
    This exact same thing has happened to my X. Im running the stock Android 2.3. I havent downloaded any apps or anything to cause this. Just out of the blue the OS started draining the battery like crazy. Was there ever a resolve to this issue? If not then I may try my luck at rooting it and installing something else on there.
    Natey2's Avatar
    19853
    112
    8 times
    I installed JuiceDefender to conserve battery.
    It shuts off your data connection when your phone is idle, and I only allow it to make a data connection every 30 minutes to pick up email, etc.
    I don't need 100% availability of a data connection; battery life is more important to me.
    Rescue Squad
    Points: 42,712, Level: 100
    DebianDog's Avatar
    6359
    "The Sticks", Virginia
    4,384
    332 times
    Have you added a new widget?
    Beamed from my DroidX
    MEANFIST's Avatar
    46746
    Aug 2011
    Quote Originally Posted by DebianDog View Post
    Have you added a new widget?Beamed from my DroidX
    I didn't change or load anything new. I did fix the problem though. I set my phone back to stock, rooted it, and installed Darkslide rom using your youtube video. So far this has fixed everything that was wrong with this phone.
    Points: 674, Level: 13
    Level completed: 48%, Points required for next Level: 26
    DonKilluminati's Avatar
    26411
    25
    Since getting .602, this problem has shown up for me.
    Started the day (9am) at 100% full charge. About 5 hours later, I was at 80%, completely normal considering how much I generally use my phone. Android OS only using 5%.
    About 2 hours later, my battery was down to 40%, with Andoid OS at 66%. What makes this even harder to bare is that I used my phone a LOT less during this time.
    "5 Percent remaining" notification popped up about an hour and a half after that, checked to find out what Android OS was at right before plugging into charger.. 79%! Yikes!
    BTW, I have an extended battery. A few weeks ago I would generally plug my phone in at night after it being off the charger for about 16-18 hours, VERY RARELY would I get down to 15% battery life, ever. This sucks lol.
  1. theme chooser draining battery
    By RnD_Solo in forum Cyanogenmod
    Last Post: 06-20-2011, 09:05 PM
  2. Toolbar Arrows- Draining Battery
    By MattRush in forum Droid X Rescue Squad
    Last Post: 06-14-2011, 12:40 AM
  3. Contacts are draining all of my battery
    By kami Kali in forum Gingerbread Help
    Last Post: 05-09-2011, 09:04 PM
  4. 3G downloads DRAINING battery
    By tcsheen in forum Gingerbread Help
    Last Post: 04-18-2011, 05:04 PM
  5. Battery Left Draining my battery?
    By eXile in forum Droid X Apps
    Last Post: 08-30-2010, 06:49 PM
android os battery drain droid x
android os draining battery
android os draining battery droid x
android os draining my battery
android os is draining my battery
android os is killing my battery
android os killing battery
droid x android os draining battery
why is android os draining my battery
why is android os killing my battery
